Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Oil leaked from housing
My KitchenAid mixer sat on its back for a couple of weeks when I moved into a new house.  When I unpacked it I noticed that oil had leaked out of the back of the motor housing.  I don't want to use it before I find out if it needs to have some sort of lubrication replaced.  How do I correct this problem?
radgrk
  • Anonymous Dec 03, 2008
    My older Kitchenaid that really never got heavy usage is doing the same thing. The oil drips around the round plate where the beaters fit. I'm still using it but have to check often to wipe it up before it drips in the food. Figure that some day it will burn out when all the oil is gone. Because of it's cost, I think that the next time iIwill buy a heavy-duty Mixmaster. I have worn two of those out over the last 35 years but they're a lot cheaper to replace and they handled dough and thick icing very well. Actually, I liked them better because they had a wider bowl and was easier to get into to scrape the bowl. Hope we find a solution to the oil problem.
My ultra power ksm90gr 300 watt mixer leaked oil when in the upright position overnight. whats that all about?
Posted on Dec 25, 2008
How to remove top housing from Kenwood Mixer 210 series
A very well briefly written post, with lots of useful information.
Thanks for sharing.
KitchenAid Professional 600 Series
Jul 15, 2012 | KitchenAid KSM150PS Artisan Series Stand...
Mixer is leaking oil from were attachment go
Inside the gear housing there is a ton of grease. When the machine is used too many time or ran for an extended time the grease will degrade and become runny that's why it leaks. Open your motor up and replace the new grease. This should take care of it. Replacementparts.com has some great videos on how to fix kitchenaid stand mixer. Here is the video on how to change the grease.
http://www.youtube.com/watch?v=8eKHVvNX5eY
Dec 14, 2011 | KitchenAid Food Mixers
Wifey dropped her mixer this evening...Now its leaking oil...Hate to get rid of it...Would like to repair it if possible..Any suggestions ?
First thing is to determine where the leak is and if the broken part is available and replaceable. If it is the main housing I think a new mixer would be a wonderful Christmas present,
Eric
Dec 19, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
How to oil kitchenaid stand mixer
First disconnect the power. After this You will need to disassemble the unit by first removing the access panel at the rear of the unit. Now you can remove the siler band around the mixer. Remove this and then also remove the screws around the upper housing. After removing these, tilt the unit to reveal two more screws. Remove these and now you can remove the upper housing by lifting the housing while slightly twisting it. After this is removed you can now see the main gears and the motor. To grease the inside gears, you will need to simply move the old grease that has been moved around and put it back onto the gears. I would also inspect the grease very carefully as sometimes there can be chunks of plastic or metal in it. Whirlpool puts more than enough grease inside the mixer to last its entire life, and the only time you ever really need to change it is if your gears have been destroyed and now is contaminating the grease.Hope this helps.
Thanks
Nov 07, 2009 | KitchenAid K45SS Classic Stand Mixer
My mixer is leaking oil. last time we made bread dough in it it sounded kind of rough. we figured wiyh the heavy load maybe that was the rteason for the noise. when we moved the mixer to clean it, there...
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
May 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Mixer leaking oil
Hi Tim. Don't try to pour anything into the side openings, these openings are for the electrical brushes. You didn't state what model you have so my help is limited. Goto www.kitchenaid.com and click on the customer care tab. Enter your mixer's model# into the search window. Look for a parts catalog for your mixer. If there is one, download it.
Your mixer uses grease to lubricate it. If it's leaking oil, the oil and old grease must be removed and replaced. Chevron FM ALC EP-2 is a "Food Grade" grease, use it to replace the old stuff. The transmission housing and Planetary assembly will have to be removed to accomplish this. It's a messy, but necessary task. Once completed, run the mixer for a few minutes each week to keep the oil suspended in the grease, this will extend the life of the new lube. Good luck!
If this solution has assisted you please rate it. ricardok45.
Mar 28, 2009 | KitchenAid Food Mixers
KitchenAid wobbles when mixing
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Dec 24, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid mixer is leaking from the part that spins?
I took mine apart and all the grease had settled down around the shaft in the housing due to lack of use,found no seal.Going to spread grease back up on gears,see what happens.I found this at KitcheAids web site.Good luck.
Dec 01, 2008 | Food Mixers
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
398 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
