Question about Sony DVP-S360D DVD Player
DVD player my dvd player says no disc when one is in...i have no idea where to find a 'lens' to clean...is this time to get a new one, or is this an easy fix?
  • JorgeJ Jan 11, 2009
    I get the "No Disc" display when I insert a DVD movie. It varies by disc and sometimes when a disc is ejected and then insterted several times, then the disc will play, I smoke a cigarette after it plays the disc.
    Would this be a lens issue or are there incompatibility issues with the newer discs and I need to get a new player? My DVP-S360 is over 5 years old.
The dvd player says no disc with a disc inside of the player?
Posted on Jun 29, 2007
Where can I find the original manual on how this operates? I think I may have entered something wrong on my Remotes, since jit will not play a DVD when I insert it. PLease advise.
Posted on Dec 01, 2008
After inserting dvd in player it reads no disc
Unfortunately , Some DVD players cant read some DVD s and
then it gives either "loading" or " no disc"..reading on the display...
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Just in case,quick remedy ,
pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
if this remedy does not help and if your set has still under warranty ,consult to service they may replace the LASER Reader EYE...most of the time Laser Eye malfunctions and does this..
if it is not under warranty ,never ,never have someone repaired it..go buy a new one,It will be cheaper.. ...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 21, 2011 | Daewoo DV-6T834 DVD Player/VCR
Most times (90% or more) I input a DVD, the TV screen says Loading, and seems to be processing the DVD loading procedure, but then doesn't play the DVD -- it stays stuck on the Loading sequence. Any...
then it shows either "loading" or " no disc"..
Thanks
Jul 10, 2011 | Samsung DVD-V4600 DVD Player/VCR
Won't play dvd
If your player wont play dvd, then it means there is a problem somewhere inside the unit. Most likely the lens is weak or dirty. First try to use a lens cleaner for the player to see if it will play any disc, if it does play the dvd, then it means the lens was just dirty and needed to be cleaned.
You can also try to clean your lens, by taking the player apart and using a cotton bud to clean it up. To take the player apart, you need to get a star screwdriver, then you unplug the player, then you unscrew the screws around it, slide off the back cover, then you unscrew the hook that is above the lens that covers holds the disc in place, then you use a cotton bud to carefully clean the lens. Before you reassemble the player just screw the disc holder that is above the lens back and plug it, then try to play a disc, if it does not play a disc still, then it means the lens is weak and need to be replaced.
To replace the lens, just take out the disc tray, disconnect the flexi ribbon that connects the lens to the main board, then you disconnect the lens itself, and replace it with a new one. then you reassemble the player back together.
This time, it will play your dvd discs.
Hope this helped. Take care and good luck
Jan 07, 2011 | Philips DVD963SA DVD Player
Tried to use a laser lens cleaner disc to clean my player, once loaded and inside the player I went to press play and follow the instructions, but my player stopped running and a (check disc) appeared on...
I have this DVD Cleaner from All sop Inc as well,this disc only do very miner cleaning to the DVD player Laser eye.Did not work on my DVD player.I have to take the DVD player aparts,littery take some Q tips and dips it in with some rubbing alchahol to clean the DVD laser eye itself.After littery take the DVD player aparts and clean the laser eye itself.If the DVD player still doesn't read and play any DVD discs?The DVD player laser eye is bad,not worth repairing,the brand new DVD player is cheap,cost only like $40 brand new one.
Nov 23, 2010 | LG DN798
The dvds are not detected - No Disc or Disc Error
Hi. These steps should help.
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Nov 22, 2009 | Aiwa HT-DV90 System
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
Player won't play any disc now
Time to look inside the dvd player. try readjusting the variable trimmer under the laser lens of the dvd player assembly. It is usually located under the lens assembly. try to adjust the lens at every 1 degree angle up to +/-5deg. sometimes it can be done. if not. time to change for new lens. damage lens is caused by using pirated DVDs or bad disc as the lens is trying to read the data on the cd.
guest.
Mar 13, 2009 | JVC DR-MV7 DVD Recorder/VCR
PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Feb 10, 2009 | Televison & Video
JVC DVD Player/Video Cassette Recorder Model HR-XV2EK
try to clean your machine by playing a lens cleaner disc coz the lens might be dirt enough not to pick on data from the discs you play. if it does not work then isuggest you change the lens coz it might be weak
Aug 01, 2007 | JVC DR-MV1S DVD Recorder/VCR
No DISC message displayed
Clean the lens by soft cloth by hand maually, lens cleaning will solve the problem
Aug 29, 2006 | Panasonic DVD-RV45 DVD Player
Sony DVP-S360D DVD Player Logo
90 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
