Question about Electronics - Others
Twin Mos flash disk is locked, cannot be unlocked.
I could not re-format my USB2 TwinMos flash disk with any PC using Windows XP environment. The disk is write-protected although I shifted the tiny switch back and forth. Can you help me solve my problem?
Thank you.
Basti
  • 1447 Answers
SOURCE: unlocking write protected pen drive
hi- some pen drive has a little switch on the ends of it, make sure you have it toggle or positioned on the unlock, look on both ends if it has a black switch to unlock it, if there is none try to reformat the pen drive, reply for any concerns. Yhanks!!
Posted on May 16, 2008
starlet4life
  • 89 Answers
SOURCE: how do u format sandisk microsd 2gb and microsdhc 4gb disks
Yeah heard about it before with wrong formats like FAT-FAT32!?
I usually just use the format feature on my kamera, try that;)
Posted on Nov 12, 2008
SOURCE: write protected flash drive
my usb flash drive shows that it is write protected when i tried to format it.
how i can solve this problem?
  • 11 Answers
SOURCE: Transcend jet flash showing write protected message
hey, i was having the same problem with the same flash drive... there are two ways how you can fix it..
1. try formatting using cmd
Go to start-->run and then type cmd and press enter
now the command window will open
in that type format X: (x being your drive)
This should work fine if not try the second method
2. Go to this website and download the recovery tool software which is exclusively for transcend flash drives.. click the link below to so to that site..
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#5
Download the recovery tool software under the topic software and install it in your system.
Now connect the flash drive in your pc and run the recovery tool application.. This will format your flash drive
Posted on Feb 02, 2009
  • 63 Answers
SOURCE: my 4gb microSd sandisk is infected and cannot be
It supposes to have a tiny lock/switch on the side. Move it up or down to turn off/on the write protection.
Posted on Oct 28, 2009
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
Tip
How to recover Windows XP password?
Setting Windows XP password can help us prevent others logging into our PC without permission. However, every coin has two sides. on the one hand, it helps us very much in our privacy protection. On the other hand, For the sake of carelessness or accidence, we are perplexed with the problem of losing password. Thanks to the development of technology, many tricks are available to <a href="http://www.windowspasswordrecovery.net/" style="font-weight: bold;">recover Windows XP password</a>. In some cases, recovering from a lost password can be very easy though.<br /><br />In order to show completeness, we start with the simplest tips that can help you regain access to a locked account.<br /><br /><span style="font-weight: bold;">You can login with another user account</span><br /><br />If you have another user account or you share your computer with others, things will be much simpler. Log into the Windows with the other account and perform the following steps:<br />1. Click "Start" button<br />2. Click "Run"<br />3. In the "Open" field, type "control userpasswords2"<br />4. Click "OK"<br /><br />Windows opens a user accounts dialog. Select the user with the lost password and click the "Reset Password" button. Enter a new password, and click ok. Click ok once again and you are ready. Now you can log on to your account using the new password.<br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Recover Windows XP password with a boot disk or a bootable CD.</span><br /><br />If there are no other users on your machine to unlock your account, you need to boot your pc from outside your usual Windows XP environment using a boot disk or a bootable CD. But this progress often presents very quickly and if you are not proficient with technology, it will be hard for you. Then how to solve this headache problem easier?<br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Ask the help of third party Windows XP password recovery tool</span><br /><br />Of course, you will need access to another PC to create a boot disk or bootable CD. Nowadays, many tools support bootable USB. Easily burn the BIOS image file to the CD/DVD/USB Flash Drive, reboot the PC with the CD/DVD/USB Flash Drive, then you regain access to your PC. Here let's take Windows Password Recovery Enhance for example. Only four steps, we can log into the PC again.<br />Step1. Download Windows Password Recovery Enhance and install the program on the other unlocked computer.<br />Step 2: Burn bootable CD/DVD or USB flash drive<br />Step 3: BIOS setting<br />Step 4: Recover Windows XP password<br /><br />Related: <a href="http://www.blog.windowspasswordrecovery.net/">Windows Password Recovery Blog</a><br />
on Dec 01, 2010 | Computers & Internet
Twinmos usb
throw it out and replace, even if you get it working again it will not be reliable to use and may fail at any time
Sep 01, 2013 | Electronics - Others
Hello my no is 08033771188 my username is chidex45 i forgot my password
To resolve these problems, you can simply change or reset forgotten Windows password with a Windows password reset disk. A password reset disk is a flash drive configured with your current password, specially formatted to reset the password on Windows machine when you ever forget it. It acts as a key to unlock the account. But the problem is that we often forgot to create a password reset disk and cannot log on computer with any user account.Of course, a common solution is to use a third party software, just take Windows Password Unlocker for example. It can help you remove lost Windows password including Windows administrator, user and domain password on Windows 7/Vista/XP/2000/2003(R2)/2008(R2), etc. You can easily reset Windows password with a bootable CD/DVD or USB flash drive in hand.
Apr 29, 2012 | Sony VAIO VGN-SZ460N/C Notebook
My twin mos pen drive is old.few days ago while i was using it suddenly after connecting to the port is was not detected.
> drive is old.
Has the manufacturer's warranty expired? If not, exercise the warranty, to get it replaced.
Try it in another computer.
Buy a replacement.
Feb 19, 2011 | TwinMOS Technologies 128MB Twinmos 802.11b...
When i inserted 4GB pendrive in the pc when i open the pendrive it doesn't open and shows write protection and it can't be formatted at this situation.
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 27, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Formatting (FAT) 2g drive left drive with only 735Mb. How do I format for the full 2g? Thanks
what device did you use to format your flash drive? is it a camera or PC?
now try to insert your flash drive in a usb port of a PC running windows vista since it has a better disk management tools. now format it from there using FAT32 file system to regain your disk space. you can also try windows xp
Oct 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Scan disk Cruzer freezes my PC when inserted into the USB2 drive. I have tried it from a dead boot to inserting it after the boot is accomplished. I had this happen on my 2 desktops. What's up?
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Mar 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Electronics - Others Logo
464 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
