Question about HP DeskJet 1200c InkJet Printer
Ink carriage will not move
My wife removed a paper jam in the printer by moving the ink carriage to the right. Now the printer will not respond to any print commands. It will not print out a test page either. Have we damaged the printer, or is this a software problem.
    President:
  • HP Master
  • 1,314 Answers
Try moving the carriage back to the left again and see if that helps.
Thanks and please take a moment to rate as fixya.
Posted on Nov 10, 2008
Info printer :E
Any malfunctions its gives error 'E'... Check paper jam, carriage struck, cartridges faulty and service related issues.checking carriage:Switch on the machine check carriage(the unit carrying print heads)moving left & right.. if its not moving, it might be struck in service station(service station located at right end and its allow carriage to rest on it during shut down as well as its cleans the print head nozzles). power the machine pull carriage out gently, don't force it..Clean encoder strip: Encoder is located back side of the carriage and its guides carriage to move properly, if encoder became dirty you will get error message, clean encoder with smooth cotton cloth.
Feb 03, 2012 | HP PSC 1215 All-In-One InkJet Printer
EPSON Photo 1400 paper feed and ink replacement problem
Asit is only a couple of months old seek a replacement under guarantee/warranty.
Jun 29, 2010 | Epson Stylus 1400 InkJet Photo Printer
Red warning lights remain on.....
Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
Jun 16, 2009 | Epson Stylus Photo R200 InkJet Printer
Cartridge jam...cartridge will not move to the left...stays right
turn off the printer and manually move the ink cartridges to the position that you can remove the ink cartridge.
turn on the printer without the ink cartridge. The printer will tell you, you need a ink cartridge, open the printer and insert the ink cartridge as described in the manual.
Feb 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Paper jam cleared but printer does not work
Jalavoie, I don't know if this will be a solution for you but some things to try: I would assume by now you've tried restarting your computer and in turn the printer as well, but have you disconnected the printer from the power. Pull the power lead from the back of the printer wait 30 seconds and replace it. Hopefully this will reset the ink carriage and fix the problem.
Failing that, have you had a GOOD look inside incase there's a bit of paper torn off still there - not necessarily from the one you just removed, it could be from a previous jam.
As you had moved the ink carriage by hand, are you sure you did not bump any of the ink tanks - for surety remove each tank and reseat it. Note:: the ink carriage should never be manually moved.
If none of this helped, can you describe what position the ink carriage is in a and what sounds the printer is making (if any) and exactly which lights are on or flashing.
**.The best way to acknowledge contribution is to rate it's relevance.**
Jan 31, 2009 | HP Deskjet 3845 InkJet Printer
Red light stays on..loud noise made as carriage moves to right..
If you don't respond to queries it is very difficult to help you. If you still have this problem can you respond with a comment, otherwise we will call it solved.
Jan 20, 2009 | Epson Stylus C60 InkJet Printer
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
HP DeskJet 1200c InkJet Printer Logo
126 people viewed this question
Ben Johnson
