8gb Emprex flash drive has died. Windows does not see it and the light does not flash
  • WestSeattleW Jan 12, 2009
    I just bought the Emprex 8 GB USB Flash Drive to transfer files from an old WIN98SE computer to a WIN XP computer. The guy at Fry's said "No problem. It will work with WIN98SE." My problem is the old computer can't recognize the Flash Drive. It is hunting for a driver to be installed and can't find one. I put the Flash Drive on my WIN XP computer and it sees the Flash Drive. When I open the Flash Drive, there are no drivers there. Did I just buy a "boat anchor" (although it is a small one)? I checked Emprex's website and they don't have any downloads available. Their last update for this PD330 Flash Drive was 2005! Help....easy with the tech terms...I'm no geek! (s) WestSeattleWayne
  • sedkosmo Apr 29, 2009
    My emprex 8gig flash drive has died. I can use other flash drives in the same port, but neither of my computers recognize that the flash drive is plugged into the port.
  • 37 Answers
Check if the usb port is enabled under device manager. right click my computer then click manage. go to device manager and make sure that there are no red X or yellow ! on any of the devices. If everything is good, try your flash drive on another usb port or another computer. if other computers cannot detect your flash drive, it's broken.
Posted on Nov 10, 2008
NEED DRIVER FOR 8GB datatraveler 101
Windows has built-in support for usb drives. If your flash drive isn't showing up under "Computer/My Computer" then there is a problem with the flash drive.
Dec 17, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I have A-data my flash 8GB usb which write is protected please tell how i can Fix it ,,when i try to format the usb it say windows was unable to complete to format
The problem isn't with write protection. The file system has become corrupt and unreadable, or at least a section of it. If you can't reformat it then it's likely dying or dead. At least you should be able to recover some of your data however...
Go here and get a FREE copy of USB Flash Drive Data Recovery Software:
http://www.easeus.com/resource/drive/usb-flash-drive.htm
May 15, 2012 | Electronics - Others
I formatted my 8GB Flash drive thinking I would clean it of the security software, giving me my 8GB nice and fresh. Now all I have is about 776KB and I can't get my 8GB back. There must be a simple...
Go to windows command prompt (assuming you have windows) and type format (drive letter): i.e. if your usb drive is reading as drive letter E: it would look like this: Format e: then hit enter. It will say "all datda on drive (whatever your usb drive is) will be erased. Proceed y n?" type Y. All done. It'll do its thing and you SHOULD be good to go... Hope this helps!
Sep 01, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
My 8GB SanDisk Cruzer when plugged in lights up, but it's not detected, both on Windows and on Mac, I don't know if it's still fixable... :(
Try reformatting your thumb drive. Here's how to do it on a Mac:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Feb 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Verbatim 8GB Store-an-go just went dead between uses. Computer does not even register a drive. Is this a loose connection.
have you tried it on another computer? There really are not connectors to get "loose" but unfortunately sometimes the drives do die. I would try is on another computer (windows XP or newer)
If it does not show up on another computer than chalk it up to experience. There are restoration services but they are very pricey. If you pursue this expect to pay $300.00 plus for recovery.
Sorry for your loss.
Nov 29, 2010 | Verbatim ® Store `n` Go USB Flash Drive,...
NEED DRIVER FOR PNY 8GB USB ATTACHE
If you're using the drive on a PC with Windows XP or Windows Vista, you don't need a driver - just plug it into the PC and Windows will recognize it and install USB drivers automatically.
Dec 07, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Sandisk Cruzer 8gb Error
Make sure you are logged in as an administrator. I'd also try the thumb drive in a different computer just to make sure the problem isn't with the thumb drive itself. The drive could also be unformatted, or formatted with a filesystem for a different platform that can't be read by XP.
Oct 20, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk 8GB Cruzer Gone Dead
As long as it shows in Disk Management in Windows, it is most likely saveable. Borrow a flash drive from a friend, GHOST it to your hard drive and then to your flash drive (Drive to Drive may be unsafe because you can mix up which is which). It should work and then you can reformat it so as not to steal your buddies stuff.
Jun 03, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Emprex cd burner/model # USB 5232Ul/install cd
Most times, you can plug the drive into a USB port and Windows will detect the device and assign a drive letter to it. If it does, the CD burning software should then be able to see it. Try googling the burner company name and model number if Windows continues seeing the drive as an unknown device.
Mar 11, 2009 | Computers & Internet
False write protect on an EMPREX 8GB Flash Drive
hiii martin....
dis type of problem comes when sm files inside d folder which iu want to copy restricted allowing files to copied...
u can copy it by fallowing procedure....
first open urs folder and select some of urs files not all of them and copy it to flash drive by makin a new folder....and similarly copy other files in that new folder..
if u do like that u can copy all files eaisly......
if it creates ore problems ask me.......
also available for live chat....
thankss
Jun 20, 2008 | Electronics - Others
Computers & Internet Logo
811 people viewed this question
David Payne
David Payne
