Question about Toshiba Satellite 1105 Series 14.1" Flat Panel LCD Monitor
Away from computer, screen goes black. cannot resume. have to turn off (reset) computer
If i leave the computer for a period of time the screen goes black. when i come back and try to move the mouse to resume nothing happens and i cannot get out of this mode. is there a command i could enter to let me resume or can i turn off this function completly so i do not risk harming my computer by cutting the power and restarting. thank you
    Problem Solver:
  • 11 Answers
It must have gone into sleep mode, Close your laptop screen and open it again, if it doesn't work get professional help
Posted on Jun 15, 2009
Samsung monitor goes blank after working perfectly for a period of time.
Have you checked monitor settings Carl? Some are set to sleep after a certain period of time. Mine was set to sleep after 1 hour (unknown to me) until I reset it. =)
Dec 06, 2015 | Samsung 933BW 19 inch Monitor
Black screen
could be a problem graphic card , failing
if you have a plug in card , then reposition the cable back onto the mother board monitor connection to test
Jun 20, 2017 | BenQ G2412HD 23 inch Monitor
Y compaq pressario v2000 goes from black screen to intermittent normal screen. The black screen is on the computer 80% of the time and then the pics fade in and out
The screen on your laptop goes black after every few seconds.
It resumes after a mouse-click or after a key-press.
Solution
Click on Start --> In search bar, type power options and press Enter.
"Select a power plan" window will be opened.
Click on "Change plan settings" next to "Balanced (recommended)".
In "Turn off the display", select "Never" from the drop-down menu under both the options "On battery" and "Plugged in".
Now click on "Save changes" button.
hope this helps
Nov 20, 2012 | Computers & Internet
I HAVE A CANON IP5200R IF I TURN IT ON, YELOW LIGHT FLASES 5 TIMES AND THEN 5 TIMES AND IT GOES ON LIKE THAT CAN ENYONE HELP ME TO FIX THIS PROBLEM
hello leif mo, these are the instructions from the CANON support page Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this answers all your questions Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 09, 2011 | Canon PIXMA iP5200R InkJet Photo Printer
There is a long silver button with a black moon on the upper left of my keyboard. When I accidentally hit it, the screen goes black. What is it.....and how do you get your screen back?
Depending on how your keyboard is configured, that key is set to do one of two things:
  1. Puts your computer to sleep. (A low power state where almost everything is shut off, including the monitor). You can resume from sleep by hitting any key on the keyboard, hitting the power button on your computer, or clicking the mouse.
  2. Puts your computer into hibernation. (An even lower power state where everything is actually shut off, but a copy of everything open is saved to the hard drive to be opened during start up. It basically allows you to turn off the computer, but be able to turn it back on with program exactly how you left it). You can resume from hibernation only by hitting the power button on your computer.
Hope this helps. If it does, please accept and rate the solution! You can leave a testimonial or contact me with any more questions you may have. Thanks for using FixYa!
May 24, 2011 | Compaq Keyboard
Error 5b00???
1. Unplug the printer (NO power or any connection)
2. Flip the whole thing Up side down
3. At the bottom, you can see there are screws
4. they are for the generator of the power supply
5. Take them away
6. And slowly take away the "brown" box”
7. Then you will see a power cord links with printer
8. Use a very small driver to release it with real care
9. Leave it for 30 minutes
10. Put it back together .... done
After that
Also, from other, but work....
The reset procedure (for canon MP130) is:-
Turn on the machine
(1) Press MENU
(2) Press SCAN COPY SCAN to enter service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
DONE !
Aug 06, 2010 | Canon MX300 Office All-In-One Printer
Do not start up, black screen
I'll asume something for this one it might help. Make sure your laptop is completely turned off [No fans turn, screen black, no hard drive light]. When you then press the power button, immediately keep pressing the F8 button on your keyboard. It should then actually display two options after a while :
*Delete restore/resume point and start windows
*Resume restore/resume point
Select 'Delete restore point' and the unit should boot up fine again.
I had a unit that was basically turbo-booting into windows, but the restore point was corrupt and it always seemed it had a 'blank screen' problem.
You can also try to access the BIOS by pressing F2 as soon as the unit starts up to see if you can actually access the BIOS.
If that all doesn't help I suggest reseating RAM.
May 23, 2010 | Acer Aspire 9800 Notebook
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
3. Release RESUME
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
Periodically the page on screen goes blank
Windows inactivity for screen saver is set. If you want it to deactivate.
On Windows desktop screen, right click mouse a pop up box will show. Select "properties" or "personalize", go to screen saver. Uncheck the box with " on resume, display log on screen". And on screen saver box select NONE this will unhighlighted the inactivity time and the logon screen. Hit apply and then ok button.
This will deactivate the screen saver.
Mar 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
Toshiba Satellite 1105 Series 14.1" Flat Panel LCD Monitor Logo
257 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
