Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Cameras dead This was purchased last Christmas and used quite a bit. Thinking the battery was dead, we recharged it, but nothing. We bought a new battery and still nothing. It's just dead. Any ideas?
  • selinaken Nov 14, 2008
    Thank you so much for your help! We're going to attempt your solutions and if they don't work we'll check out your site.
  • ltyamato May 11, 2010
    If it is a fuse, where can you get a replacement for cheap like you mention?
  • 489 Answers
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon if it is out or warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
If we can help with your repair then please let us know.
Hope this helps,
Thomas
Darntoothysam com
Posted on Nov 11, 2008
How long will batteries last if not used?
Get the batteries tested .As a motor mechanic your husband should know about battery care you could have removed them and charged them with a car battery charger or any of the trickle chargers used to keep batteries charged while not in use
May 09, 2017 | Pride Mobility Products Sonic Scooter By...
My dell laptop 1545 was working fine until last night when it needed recharging. I pulged it in and after hours of recharging it still was dead. I bought a new battery thinking that was it but still the...
Normally its the problem with the Battery. Make sure that your purchased battery is good. After that check your adaptor. You are not mentioned about battery backup. If you are getting the backup pls reinstall the operating system. Again if it showing you need to replace motherboard...
Good Luck
Aug 03, 2011 | Dell Inspiron 1545 Notebook
My canon A710 says it needs batteries no matter
My A710 did exactly the same thing. Spoke to Canon support. According to them you have to use Canon 2500 mah batteries (quite expensive - need a different charger as well). I've just bought new rechargable batteries from Sanyo (Eneloop pre-charged). And it solved my problem. I've also changed the batteries quite a few times and it never worked. But this did solve the problem for me.
Nov 04, 2009 | Canon PowerShot A710 IS Digital Camera
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Jul 20, 2009 | Canon PowerShot A710 IS Digital Camera
Last year I bought my mom a digital camera for christmas. It worked great for about 2-3 months. Since then it is speratic, it will turn on let you take a couple of pictures then shuts down all by itsels....
Hi! Most digital cameras require outrageous amounts of power to work properly. Be sure to use only high quality, hi power ni-mh rechargeable batteries. Check for Sanyo Eneloop or Duracell. Sometimes we think the camera is broken, but in most cases is only insufficient amout of power. If you can't find the before mentioned batteries, look for 2500mA NI-MH type rechargeable batteries and a proper charger. Good luck!
Nov 22, 2008 | HP Cameras
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
May 13, 2017 | Kodak EasyShare CX7430 Digital Camera
This might be a crazy question
Depends on the amount of use and the amount of turning it on and off. Typically, not very long. The best rechargable batteries I have found for longevity are the Rayovac Hybrid rechargeables. They last a long time and when you buy them, they are already charged and ready to go. I bought my mom a new camera for Christmas and bought her this with the charger.
Aug 05, 2006 | Kodak EasyShare Z650 Digital Camera
Types of batteries.
You can use AA disposable batteries (alkaline or lithium) or rechargeable (NiMH or Nicad) batteries. Lithium batteries last much longer, but are generally quite a bit more expensive than alkaline batteries. You should never mix old and new batteries or different types of batteries. If you use Nicad batteries, it is recommended that you use a Nicad conditioning charger to extend the life of the batteries. Note: If you use rechargeable batteries, you will need a battery charger. The camera's AC power supply does not recharge batteries.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
137 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
