Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Amana Bottom Freezer
My Amana refrigerator is about 4 years old. It is the kind that has the freezer on the bottom. It has been forming a layer of ice on the bottom of the freezer, and will sometimes leak on the floor. I've cleaned underneath it and also took off the bottom panels in the back and vaccumed the dust out, but it is still forming ice on the bottom. Any suggestions?
  • Anonymous Jan 19, 2009
    I have exactly the same problem ice accumulates on the bottom of my bottom amana freezer. Every week or so I have to remove the layer. If I dont it spills to the floor, did this fix work?
    President:
  • Amana Master
  • 2,651 Answers
Either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Posted on Dec 01, 2008
Amana bottom freezer has brown liquid draining on floor near the left leg
Posted on Jan 10, 2009
ICE FORMS IN FREEZER BOTTOM,
Keep the bottom of your freezer free from ice. ... The water from the melted ice and frost drains through a short tube and into a pan beneath the refrigerator, where it evaporates. Should the drain line become clogged, the water has nowhere to go and it freezes, forming a layer of ice in the bottom of your freezer.
How to Fix an Iced Freezer Bottom ' Home Guides ' SF Gate
homeguides.sfgate.com/fix-iced-freezer-bottom-42777.html ICE FORMS IN FREEZER BOTTOM Google Search
Oct 23, 2017 | Refrigerators
Automatic ice maker stopped working, Checked water supply to back of freezer, and the water supply is on. Arm on ice maker seems to be in correct position. there is no water in ice maker. can feel the...
Assuming you have active water supply to unit, either water valve or ice maker is bad. If Ice Maker is sending power to valve during Ice cycle, then valve is bad. If no power to valve during Ice cycle, then ice maker is bad.
Sep 11, 2017 | Amana ARB2557CSR / ARB2557CSL Bottom...
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
Ice maker freexes ice together
maybe too much water going in to the ice maker
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Layer of ice in freezer. How do I access drainage tube to clear i
It is in the freezer compartment but you can try accessing  it from the bottom where it goes into the drip pan. Try using a can of compressed air with a straw held tightly with your fingers and blow out the line backwards.
Not a lot of infor ar pictures in you manual . It does say to make sure it is level and shows hot to do so. See below:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=AFD2535DE&siteCd=AMA
Dec 20, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
802 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
