Question about Brother MFC 1850MC Thermal Printer
Same problem w/output
I too only get the left half of a page when i output anything on this machine. Very frustrating since i've moved the office and misplaced the manual for this thing.
  • 1 more comment
  • Anonymous Nov 07, 2007
    the fax machine only prints on the left side
  • t boz Nov 25, 2007
    Same problem .. only prints on left side of paper. Replaced ribbon but didn't help.
  • dlmoore Feb 28, 2008
    My fax machine only prints on the left side of the paper and I have already replaced the ink cartridge.
    Problem Solver:
One of the BLUE levers that hold the the top of the imaging unit to the printer has cracked. If you look carefully on the side that is not printing and flex the lever you will see a hairline crack. You can buy these levers at a office equipmt repair store.You can also try gluing or taping a screw to hold the unit to the frame. What is happening is that the imaging unit is not close enough to the film to transfer the image onto the page. Happens all the time on these units.
Julio (originally solved by Sue O in www.fixyourownprinter.com)
Posted on May 30, 2008
  • Gus Derocco
    Gus Derocco Mar 14, 2011
    thank you brother Julio,you saved the day,worked fine with the tape.
SOURCE:
My samsung scx 4828fn is showing out bin full
This could be related to a paper jam or a problem with the paper full sensor not moving freely. Turn off and unplug the printer. Remove the paper in the output tray. Check for a paper jam at the output. Look for anything blocking the sensor on the left side (or center) of the output tray. This sensor is a little plastic flag that should move freely as paper flows into the output tray. (This will be on the roller at the exit of the paper flow path at the output tray.) Try flipping it gently with a finger. If it is stuck, try to loosen the sensor; you may be able to clear the problem using canned air. Note: the flag can break if too much force is used. If the flag remains stuck or is broken then the printer requires repair. If the SCX-4828fn is out of warranty, decide if it is worth repairing. If it is less than a year old, contact the manufacturer.
I hope this helps.
Sep 10, 2018 | Samsung Office Equipment & Supplies
Replacing the fuse in an ultima 65 laminator
Hello, I found the service manual for the laminator.
https://www.manualslib.com/manual/838190/Gbc-Ultima-65.html?page=42#manual
page 42 shows the left side blow out. #16 is your 15A circut breaker, located on the underside of the left rear of the machine. Page 43 lists what all the numbered parts are if you need to know anything else. It doesn't give explicit instructions on how to remove, it but it shouldn't be difficult. Be gentle but firm and don't jerk it out or you might damage the connectors. Hope this helps.
Sep 27, 2017 | The Office Equipment & Supplies
How do i clear paper jam after tearing half of the paper leaving other piece locked inside machine?
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Jul 20, 2014 | Canon Pixma Mx432 Wireless Inkjet Office...
Why does my MX420 stop printing halfway?
Hi . If copies are doing fine maybe is a network or drivers issue
May 17, 2017 | Canon Pixma MX420 All-In-One Printer
I cannot print a whole A4 page although the printer is set to A4 - ie labels only print one column
You can do several tests to understand where the problem is.1. Try to print a test page - Go to Printer Devices - Right click your printer and select Properties - Click Print Test Page button like on the picture below
11_29_2011_9_40_40_pm.jpgIf the result is still like your description, you are facing hardware problem like defective toner cassette or drum.2. Try printing from different sources - print a page from your browser like Internet Explorer - print a page from your Office Application like MS Office or OpenOffice - print from notepad - print from Image viewer application
If your printer prints only the left half of the page - this is definitely hardware problem. If you receive different results from different sources, find out wich one of them does the described printout and try to discover the setting that causes the problem and restore it.Sometimes when we talk about MS Office this problem is caused by Print Area setting. You can just Clear this Print Area from Page Layout like on the picture below.
Nov 28, 2011 | Epson Stylus Office Equipment & Supplies
Ricoh 1045 only printing on 1/2 page
When you put the delveloper did you:
remove the cover to install it.
remove all of the old developer out of the machine.
Did you go into service mode and run sp 2-801.
Jun 30, 2008 | Ricoh Aficio 1035 Copier
Printer prints first page with strange nonsensical characters
I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
May 28, 2008 | Dell 1720dn Laser Printer
Only one-half (righ side) of the shredder works, left side does not shred
Fellowes has a five year warranty on the cutting block of their shredders. (The cutting block is that part of the machine that actually does the shredding of the paper) Take it back to the store where you bought it ans they should either replace the cutting block or exchange the entire machine, but it will take about a week or more, depending on where you are located. At least it shouldn't cost you anything.
Sep 05, 2007 | Fellowes Powershred 480 Shredder
Brother MFC 1850MC Thermal Printer Logo
67 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
