Question about RCA RCU300WBL Remote Control
System link3 issue
I did the code search, tv went off pressed enter, now won't do anything for me won't turn on// chng channels etc so I found the code thru search, no idea what to do from here?? TVi s a sylvania
  • suzieql8 Nov 10, 2008
    CRCU300CP code under battery cover.
  • Anonymous Nov 30, 2008
    exactlly the same
I need the code for a universal remote control it is a bd-512
Posted on Nov 10, 2008
I have a soyo tv and the codes on the setup sheet do not work
Try a code search method. If the remote have codes for your TV, you will won. It is a time taking procedure. Check it. Here the procedure is.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out
Oct 14, 2012 | Soyo Televison & Video
4-in-1 remote auto search and save codes for mitsubishy tv
Codes for Mitsubishi TV are: 0005 0151 0051 0004 0009 0254 0022 0141 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Jul 14, 2012 | One For All URC-3021 Remote Control
THERE IS NO CODE SEARCH BUTTON ON MY REMOTE
Direct Code Entry
Code Search
Jul 07, 2012 | Televison & Video
Tv code for symphonic
0053 0189 0227 0456 0024
Direct Code Entry
Code Search
Jul 04, 2012 | Televison & Video
Rcr311b remote won't code to Sansui tv
Code Search
Jun 27, 2012 | RCA RCR311B Remote Control
How do I reprogram my g e universal remote control model rc 24912 - e 3839
Direct Code Entry
    Code Search Method
Apr 16, 2012 | RCA Audio Players & Recorders
What do you press to program remote to sharp TV
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
    Code Search Method
Apr 15, 2012 | Sharp Televison & Video
Remote control for konka K2979
Hello
You just buy one Philips Universal Remote Control model number [CL 034]. Your TV, Konka is listed in its codes. The codes and entering procedure are given:-
Codes For Konka:-
0906 0702 0203 0306
................. 0208 0911 0842 0942 0504
Direct Code Entry
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
flashes.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
6. Press and release MUTE to install
the code.
OK.
Dec 15, 2010 | Konka Televison & Video
How to set a remote for a philips universal cl034 for a sanyo tv
1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
2. Press and release the desired mode button (TV,VCR, etc.). The red indicator blinks, then stays lit.
3. Enter the 4 digit. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes direction to forward again.
Jan 02, 2009 | Philips PM3S Remote Control
Lost directions for universal remote control
Found the codes after an aggravating search, lost the instructions myself but finally found a copy:
Express view sat. codes: 0654, 0647, 0655, 0628
Star choice sat. codes: 0640, 0645, 0627
Sanyo TV codes: 0049, 0097, 0110, 0004, 0268, 0012, 0108, 0180
Nexxtech should post these - you get what you pay for I guess.
Jan 12, 2008 | Televison & Video
RCA RCU300WBL Remote Control Logo
123 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
