Question about Kenmore Sewing Machines
Kenmore sewing maching model 158.904
I need bobbin winder rings for kenmore model 158.904
I bought mine at Walmrt. They are a Singer product and says it will fit most machines. There are 2 belts in the package and the small one is for bobbin winders. I have a Kenmore 158,904 and it fits perfect.
Posted on Jan 21, 2009
2 Suggested Answers
  • 69 Answers
SOURCE: Kenmore Sewing maching 158 15510: sewing mechanism
You put the hook (the half moon thing with a sharp point on it) in the machine by placing it opposite the little curved bar. Make sure it is seated properly on the ridge. The you take the race, the circular part with a small plate on the top and place that over the hook(the plate side will be facing up). It will only fit a certain way, it could have a slot that a notch fits into (that is usually how it goes). Then slide the arms over it and they will snap into place. Once done, turn the handwheel and make sure everything moves smoothly. If not, you'll need to start over as something isn't seated correctly. Then you can install the bobbin case as usual.
Posted on Mar 01, 2009
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ... > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
Loading thread on the bobbin old Kenmore sewing machine
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
I need to replace a friction ring on the bobbin winder of a kenmore 158.17560 sewing machine. I need a schematic of the parts involved with this. HuggyBear
Bobbin winder rubbers are standard on 99% of machines and you can get them from any sewing machine shop and some large stores
Sep 20, 2013 | Sewing Machines
Bobbin rewinder won't work
it's possible that there is a part inside the machine that could be broken, it would be a good idea to have the machine checked.
Jun 23, 2013 | Kenmore Sewing Machines
Need bobbin winding ring for Sears Kenmore model # 148.12140, no longer avail at parts online. Is this ring available anywhere else?
part number 1939 Looks like a normal bobbin winder friction ring. Try sew classic. they have some generic ones in a few different sizes. (btw.... looks like a Janome one might fit, but I didn't find it)
Aug 29, 2012 | Sewing Machines
The bobbin on my kenmore sewing machine model 158.15720 won't spin to wind the bobbin. I oiled it but it didn't help. The belt is a little loose. Could replacing it help?
most machines will have a rubber o ring as part of the bobbin winding mechanism, when you engage the bobbin winder, this o-ring will move over against the main engine drive wheel and this then makes the bobbin spindle turn. So yes, you may need to replace the rubber o-ring, they can perish and wear. Called Bobbin Winder Tyre, you could try, they have loads of Kenmore models listed but can't see yours. However, if you email them, they should be able to advise what part number it is. If you start by opening up the machine case and take a look at the bobbin winder area first, you may find this rubber has split or perished.
Oct 11, 2011 | Elna 2007 Mechanical Sewing Machine
Bobbin won't wind on Sears Kenmore model 1756
You need a bit of oil on you bob winder shaft and then work it in turning your bob winder or your bob winder rubber ring could be worn.
Jan 19, 2010 | Sewing Machines
bobbin wont wind on sewing machine
Apr 03, 2009 | Kenmore Sewing Machines
Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
The winding sound is the rubber O-ring against the spinning pulley (back of hand wheel) - do not let this continue, it will wear out the O-ring.
I had the same problem and I found the shaft bushing of the winder dry and needed lubed. Use oil or spray lithium grease and it should work fine. Spin the bobbin shaft by hand (not the hand wheel) to get it freed up after oiling.
You can oil from the top and should take off the side case to clean the excess oil from the O-ring. The shaft bushing is a tight fit and any dry oil will get sticky and prevent winding.
Jan 22, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
458 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
