Question about Digimate DGL32 32 in. LCD Television
Weird yellow light
Hi, My problem is when I shut down my home theater reciever [which is connected to t.v ] the power light on my t.v turns yellow. This is not normal because It only goes green for ON & red for stand by or no sync detected. When this light goes yellow I can't turn the t.v back on untill I unpug it & plug it back in. Any idea's ?
We lost the remote for home theater system during our last move. Somehow, the sleep timer got activated, even though there is no remote. How do I shut it off again without the remote?
It's a bit weird that the sleep timer keeps coming every time you power up. Have you let it shut itself down by allowing the sleep timer do it? If it still does it then, and there is no button that will cancel it on the unit itself, try pressing them all, then you will to get either a universal remote or see if there is an original. As I don't know the make or model number of your system that is the best answer I can give.
Feb 02, 2016 | home Audio Players & Recorders
Protect subwoofer showing on power amplifier
Check your owner's manual for a Factory Reset, or Return to Default. Try that first. If it still doesn't work, try disconnecting the sub completely, and see it that resolves the issue.
Feb 03, 2014 | Sony MUTEKI HTDDW1600 Theater System
Hi !i could not get the picture. i can hear only
Are you connected via HDMI, Component, or regular red, yellow, white cables. Make sure the cables are plug in all the way nice and tight. If you have HDMI cable, remove it for a minute or two and then plug it back in. Or shut your home theater for a minute or two and plug it back in. Turn it on and and put a dvd movie to see if it works. Hope it works.
Jun 24, 2010 | Samsung HT-DS630T System
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
May 10, 2010 | Yamaha P2500S Amplifier
OVERLOAD Message followed by receiver shutting down.
The First step in this would be to Check the Ohms Limit in the Manual and Compair to the Ohms on the Speakers that you are running and the Ones that came with it. Usually when you By the "Kit" the Speakers are Factory Matched with the Reciever. Let me Know!
Jan 02, 2009 | Pioneer Audio Players & Recorders
Protection
sounds like you may have your speakers connected wrong or too many speakers. Check all your speaker wires for a goo tight connection and speaker compatibility with your Home theater system. Hope this will help you
Dec 20, 2008 | Sony MUTEKI HTDDW1600 Theater System
Vsx-d506s problem
It may be a PROTECT MODE. Check is your other equipment properly connected to receiver.
Oct 09, 2007 | Pioneer VSX-D506S Receiver
Horrible playback
you have it on progressive scan turn it off using the remote, slide down the front.
Aug 31, 2007 | Samsung HT-DB390 System
Unit won't allow me to change modes
If you're NOT still under warrantee you should at least open the reciever and look for a blown fuse near where the power cable enters the set. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the receiver to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your reciever serviced.
Jan 17, 2006 | RCA RT2380 Home Theater System System
Digimate DGL32 32 in. LCD Television Logo
Top Digimate Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
sureshd2008
Are you a Digimate Televison and Video Expert? Answer questions, earn points and help others
