Question about HP PSC 1410 All-In-One InkJet Printer
Hp1410 will not turn on
I have checked all the connections. Everything is fine, Nothing is loose.
Printer will not turn on. I have depresesed the "on/resume" switch several times. It will not light up either.
rjleeder@gmail.com
    Scholar:
  • 121 Answers
Check to see that u getting power out from the adapter itself...it could be a faulty adapter....use a multimeter measure voltage to check you getting any readings....
Posted on Nov 10, 2008
No hydraulics working yet everything was fine the night before
My thought also. Does the engine run but hydraulics not work? If engine has a starter, check the battery and battery connections.
Need more information in detail.
Nov 27, 2014 | Garden
Just put a new battery in my Cadilla STS because I thought the old one was dead, but after putting the new one in everything seemed fine and trunk, doors, radio, lights all worked. I turned the key and...
Sounds like a loose connection on the battery. Clean and tighten them, and check the battery ground. Is the starter cable on tight? If still nothing, a shop needs to check the ignition switch for a defect.
Mar 22, 2013 | 1995 Cadillac Seville STS
Does my hp1410 all in one scan and print negatives?
Your HP1410 cannot scan negative and print it.
Thanx
Jul 24, 2010 | HP PSC 1410 All-In-One InkJet Printer
Can't scan from HP1410 all-in-one to computer
get the specific driver on www.hp.com/ if you don't find it there, try on google, there is a lot of good web sites to download that.
Aug 11, 2009 | HP PSC 1410 All-In-One InkJet Printer
Won't turn on
If you do not have a volt meter, there are some things to try. The first couple of things sound silly at first, but we have to check it.
1. Plug something else in the outlet you use for your printer...verify the outlet has power. You probably use a surge protector (power strip) and we need to verify it has power.
2. Remove the power cord from the printer (if it is the type you can take out) and swap it with the power cord for the computer. A cord we know works! The cord may be loose where it connects to the printer...and snug in the wall.
3. If this fails to get the printer going, we'll need to take a look inside and make sure no fuse or overload switch is tripped or blown.
Good Luck!
Apr 07, 2009 | HP Photosmart 8250 InkJet Printer
I misplaced my connecting cable ie printer to laptop
USB interface cable..Radio Shack or Frye's keeps these in stock..usually around 5 to 7 bucks
http://tinyurl.com/6qcpgy
Apr 09, 2008 | HP PSC 1410 All-In-One InkJet Printer
I can't get the scanner to work on my mp160. The printer and copier work fine.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-13
Feb 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
H.P F380
Please pardon the apparently obvious questions but unobserved incidents occur and this may be relatively simple
Is the device plugged in securely? There are three possible points of disconnection? I have had cables loosely plugged into power bricks that appear connected but in fact were not.
If plugged into a powerstrip is the power strip on?
Is the printer on?
Is the USB cable properly connected at both ends? it may have slipped loose.
Is the printer displaying an error such as out of paper or empty ink cartridge or paper jam?
Dec 08, 2007 | HP DeskJet F380 All-In-One Printer
HP PSC 1410 All-In-One InkJet Printer Logo
37 people viewed this question
Ben Johnson
