Question about Microsoft Xbox 360 Console
MTU fail i wanted to setup xbox live in my room so i got a router(2wire 2700HG-B) and it says the MTU is failing, so then i went and searched the web to see how to fix it and alot of websites said to download this Dr.dcl thing and i did but it still failed.     PLEASE HELP!!
Ok well I found a fix but it may not be simple. anyway, i got my xbox360 to work off of my girlfriends laptop by feeding internet to the laptop from the cable modem via usb and then from the laptop to the xbox360 via ethernet. just right click usb connection in network connections and click sharing tab, then activate sharing and tell it to share connection with lan connection... you can also share through wireless if your xbox is wireless. I tried running all this through a dsl wireless router and a basic hub and both of them gave ip address and mtu errors... good luck
Posted on Nov 10, 2008
I have a xbox 360 that fails the mtu portion of the network connection. i have at&t dsl that is run through the phone jack to the router ( 2wire 2701hg-b) and from the router to the xbox. what do you...
check on the MTU settings of ur 2wire.
This are the steps to see what ur MTU setting is:
>connect a computer to the 2wire
>open Internet Explorer, Safari or Firefox
>enter this on the address bar:
>enter ur system password (in case u forget this, click on i forgot my password to get a hint)
>look for Advance in the column on the left
>click on configure services
>on the bottom, u shud see the MTU number
** i searched online and accdg to xbox tech support, ur MTU should be in the range of 1364 to 1500 **
>click on submit after u change the setting
just in case youve entered the correct MTU setting but it still does not work, u might need to contact either xbox or ur internet service provider.
Keep me posted on this one.
Dec 24, 2008 | 2wire 2700HG-B Router (2700HGB)
Xbox live cant connect mtu failed
This appears to be a common problem, most likely due to the recent Xbox Live server maintenance. Nothing we can do except for wait until Microsoft fixes things on their end.
Sep 30, 2008 | Microsoft Xbox 360 Console
MTU setting
Browse to the router's setup page, should be or and log into it. You just have to change the MTU. Put it to 1500.
Once logged in to the router, go to :
Basic Setup
Wireless Setup
Internet Connection Type
Connection Type = Static IP
Internet IP Address =
Subnet Mask =
Gateway =
Static DNS 1 =
Static DNS 2 =
Static DNS 3 =
STP = Enable
Optional Settings (required by some ISPs)
Router Name = client-mode
Host Name = 2WIRE383
Domain Name = [empty]
MTU = Auto
Please remember to rate all users who assist you for free :)
Sep 29, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
360 mtu test keeps failing
Access the routers setup page by typing (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Aug 02, 2008 | Microsoft Xbox 360 Console
If you have your Xbox connected through a router, most routers, on their control panel ( for example) give you the option of setting an MTU, or leaving it to default. This option is normally found on the setup page of your routers control panel.
MTU stands for maximum transmission unit, basically a speed thing.
If you can set it, change it to something above 1500 depending on how fast your internet connection is, but I am fairly certain that 1500 is the minimum that you would want to have set for xbox live.
Another way to do it is, if your router has this option, set the MTU to Automatic. That way your router (should) be able to do all of that dynamically as the need arises.
I hope this helps to solve your problem, good luck!
May 16, 2008 | Microsoft Xbox 360 Console
Mtu failed
what kind of router are you using to connect your xbox 360 to? usually you can define the MTU size in the router configuration.. default for xbox 360 live is 1364 ... check out your web configuration on your router to see if you can change this!
May 02, 2008 | Computers & Internet
2wire 2700HG - B
Log on to the routers interface and look for MTU size. Once you get there, reduce it to 1492. This will help.
- Ranjit
Nov 02, 2007 | 2wire 2700HG-B Router (2700HGB)
Microsoft Xbox 360 Console Logo
203 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
