Question about Whirlpool GEQ9800P Electric Dryer
Dryer It wont tumble just make a humming noise when started. The tension pully popped off so i put it back on. It still wont tumble.
    President:
  • 878 Answers
Beckerkim, you have one of two things going here, either your blower wheel has something jammed in it or it's broken or the motor itself is shot. Check the blower wheel first make sure it's ok. You also may want to check the drum rollers to make sure they are not seized up. Catriver...post back.
Posted on Oct 28, 2006
My tumble dryer is making a noise when on and drum is not turning
Either
-the drive belt has slipped off or snapped (revving motor noise)
-the belt tension spring has broken (revving motor noise)
-the motor start capacitor has failed (heavy hum noise)
Nov 25, 2013 | Dryers
Whirlpool tumble dryer making a loud noise
the dryers drum that spins around is driven by a belt . A belt tensioner is attached to provide a secure fit when turning. The tensioner has a idler pully which has a bearing in it. When worn the bearing squeaks or wears out causing this noise you have. Sears sells the belt and idler pulley as a set to retify this situation you have. Instructions come with these kits
May 11, 2012 | Dryers
Good Morning: I have an older Kenmore Dryer with the serial # of : 77982600 and the belt broke. I can get the new belt but am wondering how it goes on. Do I have to remove the felt belt on the backside?...
dont mess with the felt on the drum... pop the top of the dryer. 2 clips hold it down.. use a screw driver to pop it. then take out screws on the front and bottom to remove the front part of dryer with the door . now put the belt around the drum put front on. then comes the fun part feeding the belt through pully tensioner good luck remove back to get to belt pully /tensioner
Aug 16, 2010 | Kenmore Dryers
DRYER RELUCTANT TO START TUMBLING AND OFTEN WONT REVERSE..IT GETS STUCK WITH A HUMMING NOISE
Check the motor...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 08, 2010 | Hoover HDC7FME Electric Dryer
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
I just finished drying a load of clothes in my hotpoint front load dryer; & now my dryer is just making a humming noise & won't start
Is this a repeat question?
Broken belt - pop the top - remove the front ... get a new belt - put it around the drum, through the tensioner and over the motor pulley. Reassemble.
Get belt at Fixya advertiser, local appliance parts place or www.repairclinic.com
Oct 20, 2009 | Dryers
Tumble dryer ,creda tcr 13
hello dave to do this you'll have to take the front panel off so you can pull the tumbler out so you can get to your pully and tensioner on the bottom on the dryer,loop the belt on the pully and keep tension on it while you slip the tumbler back in now loop the belt around the tumbler and after the tumber is sitting on your glides spin the tumbler till the belt is in place,if you can have somebody help you its easyer putting the tumbler back in with 2 people while keeping the belt on the pully on the bottom of the dryer. any other problems or questions let me know i've dont mine about 6 months age its a little pain in the **** but not inpossable
Apr 09, 2009 | Dryers
Tumble dryer
Hi Drinkben, Pull the dryer out and disconnect the power. Pop the top up and raise it like the hood of a automobile. The Front that the door is hing from will either pop off or you may have to remove screws to get the front to come loose. Once the top and front are dsilocated, you can clear the old belt. Put the new belt over the drum and raise the drum a bit to allow the belt to go undeneath. Thread the belt so that it araps the tensioner and around the motor pully. Roll the drum by hand to besure the belt tensions properly. Then reassemble the dryer. Plug n the power cord, and slide it into place. This is an Easy job to do and with your Ingenuity , I am sure this will help you complete the task.
Sep 29, 2007 | Dryers
Whirlpool GEQ9800P Electric Dryer Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
