Question about Sony KP-57WS500 57" Rear Projection Television
Sony KP-57WS500 convergence drift
I recently aquired a Sony 57" TV. I replaced one of the video driver IC's and a few resistors and got the set running. I seem to have a convergence drift problem. I can run the set four 4 hours, set the convergence in 480 and 1080 modes, save, and exit. After power-down and back on, I see a convergence shift within 10 minutes. Can someone point me in a direction to pursue? I have another set with a shorted CRT I can steal modules and parts from if necessary. Could this be a sign the convergence IC's are worn, power supply issue or convergence module?
Any ideas would be appreciated.
Thanks,
Dan
  • Dan Smith
    Dan Smith Nov 15, 2008
    Well,
    I centered the geometry of all three guns and then performed convergence.
    It seemed to help stablize the convergence, but the set must warm up about 10 minutes. I'll replace the electrolytic caps on the convergence IC's to see if it helps.
  • Dan Smith
    Dan Smith Apr 28, 2009
    I replaced the electrolytic caps at the convergence amps and cleaned and applied new thermal grease. Seemed to help. Sold the set for $100.00 to make room for a Mitsubishi.
  • Sony Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Sony KP-57WS500 convergence drift - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
Wavy color separation, auto focus doesn't fix problem. Doesn't have a manual focus.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
Oct 11, 2010 | Sony KP-57WS500 57" Rear Projection...
The colors aren't lining up properly on my Sony rear projection tv.
Oct 06, 2010 | Sony KP-57WS500 57" Rear Projection...
My tv is a 57ws500 and the picture is shadowed by red color and can't seem to get the red out. what do i need in order to have picture in excellent working order?
Ur convergence is dead.Must know how to solders?Must replaced 2 STK convergence and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 17, 2010 | Sony KP-57WS500 57" Rear Projection...
Tv picture problesm
hello it sound like convergance ic may be the trouble
regards
shaun
Feb 06, 2010 | Sony KP-57WS500 57" Rear Projection...
There are red, blue and green lines going all the way across
it sounds like a convergence problem; in the customer menu there is an option to adjust it with the Sony remote---if either blue or red will not adjust in some direction---you have a bad IC---this set uses two STK-392-560 IC chips for convergence---both would need to be replaced and the set adjusted again. If this has been helpful give me a vote here---if you need more direct assistance--------- etower.766@netzero.net
The convergence IC chips are available on Ebay from Surburban Electronics for less then 14 dollars for the pair.(plus shipping)
Aug 15, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony 57" dlp TV CONVERGENCE problem
You have to pull the chasis completly out the set. Make sure you know where all the wires go that u have to unplug. Also u may need to change open resistors near the convergence amplifiers.
Apr 23, 2009 | Televison & Video
Convergence IC`S
Let me know do you have related service manual of Sony KP-57WS500 to guide you further?
Without service manual it would be difficult for you to understand our directions like what to check and where to go in TV etc.
Sep 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony 57 inch
Hello
there is two STK packs in your TV, this is what controls your convergence,it should be two big IC on big heatsink and number should start with STK- ______,just replace these STK packs and you can order these from matelectronics.com. Parts should be somewhere around $30 and also make sure that resistors around stk packs don't look like they been hot if they look like they been hot just replace them too, and your TV will be working fine.
Thankyou
May 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 inch TV
Probable convergence IC failure = replace both for reliability..T.
Nov 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500
the unit needs the convergence ic's replaced and probably a couple of safety resistors.average repaire are about 300 from a tv shop
Mar 04, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
273 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
