Problem with numark cdn 88 disk loads but does not read
  • DJ Ken Nov 10, 2008
    Thank you. This is my older player. I have a Denon system as well. I use the Numark for smaller gigs. My latest project is putting together a virtual system on a laptop. Almost there. Thanks again.
    Ken
  • Anonymous Jan 05, 2009
    disc sticks
My best suggestion, if it won,t read any discs then it need repairing. go through your newmark retailer .they can normally get it fixed by numark. newmark players do go this way unfortunately. if it happens again ,don't buy cheaper models in future. i have had numreous problems with numark axis 9 cd players and in the end i replaced them with a different make.
Posted on Nov 10, 2008
What laser is in CDN 88 pro
Its looks like a SONY brand with KSS laser 213c .
Feb 13, 2014 | Numark Industries Numark CDN88 PRO DUAL CD...
One cd player wont read
Take a can of compressed air and blow into the player all around and try it. The heads get dirty over time and stop reading. Clean the dust off the laser head and they usually start working again.
Feb 28, 2013 | Numark Industries Numark CDN 22 Mk4 Double...
Numark cdn25 dual cd player when open close the lcd screen gets dim
Are you using the original factory power supply? That sounds like it isn't strong enough. The mA is what I mean.
Feb 28, 2013 | Numark CDn25 Professional DJ CD Player
Numark cdn 90 door opening and closing cd not reading
my numark cdn90 door opening and closing cd not reading
Sep 05, 2011 | Nu Mark Numark Cdn36 Dual CD Player CD...
Use the cdn22 on weekends for 6 hours a night. at least twice a nightone of the cd players said no disc when i put one in. its not always the same side that does it. the only way to correct it is to power...
Check for contamination on the disks that won't load. Also if you have things like cigarette smoke or "fog" machine that can cause the problem. The precision of the head of the CD players is amazing as the tracks are millionths of an inch apart and it doesn''t take much to cause a problem. If trying to load again the disk finally works, then it may not be registering on the hub quite right. Care in centering MAY help.
Mar 14, 2011 | Numark Industries Numark CDN 22 Mk4 Double...
Cdn 88 not reading cd
Hi, the main board will issue this (no disc) error code when the lens assembly is malfunctioning. this assembly incorporates the lens head and body and tracking rail. this rail has a motor and gear assembly that has to work in unison in order to track and read properly. the (no disc) error is signaling ga serious malfunction within this assembly. it is not tracking. this will cause errors and the lens will not be able to scan for data to transfer to the main board for track display and info.
numark does all the repairs in house so, you will have to send this unit to numark for the lens assembly replacement. it has failed.
May 22, 2009 | Nu Mark Numark Cdn36 Dual CD Player CD...
Left jog wheel on CDN *88 remote controller not working
Hi tmal004,
I don't have a technical manual for this unit, but I have worked on these before. They are fairly easy to dismantle, take care to apply even pressure when removing the jog wheel, use something like a butter knife (2 off) to slide under opposing sides of the wheel and gently prise up. Spare parts for this unit are available directly from Numark, however you can source them from elsewhere. you'll probably need to replace the transducer.
Good Luck.
Feb 13, 2009 | Numark CDN95 2-Disc CD Player
My Numark Cdx and Numark Cdn90 are frozen
Hi Mitchdias,
Have you tried downloading the most recent rom update for the CDN-90? All you need to do is download it from here http://www.numark.com/contentmgr/showdetails.php/id/1493/tt/5 , then burn the download to disc. Once that's done, put the disc into the player, switch the player off and wait 10 seconds, then switch it back on again. the player will read the disc and flash the ROM. this should reset the player for you. Before you ask, you can out the disc into either side of the player. Full instructions are given with the download.
Jan 05, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Play button on numark cdn-88 does is messed
The problem is the play button itself. The controller has to be disassembled and the TAC switch needs to be replaced. Would not recommend you do it yourself unless you are good with a soldering iron. It is easy to damage the circuit board with excessive heat or if you are not very gentle removong the existing switch.
Nov 25, 2008 | Nu Mark Numark Cdn36 Dual CD Player CD...
I have got a Numark cdn-88 cd players for my work as a DJ but draws wont open on both sides and it is clicking when I turn them on
The loading mechanism is out of alignment or the start/stop sensors are defective. Either case should be a simple repair for any audio repair shop.
Dan
Oct 01, 2008 | Audio Players & Recorders
277 people viewed this question
 Grubhead
Grubhead
