Question about Fuji FinePix A345 Digital Camera
Blurry picture my son dropped my camera today and now the pictures are blurry. what should i do.
  • Anonymous Mar 30, 2014
    When I take pictures of my daughter playing volleyball they are blurry even when I have it set on the sports mode. How do I set the camera to take pictures of moving objects or sporting events
I have this same problem. If I shut the camera off then on again it clears up. Someone from Fuji said that this is because the Auto-Focus is stuck on. They advised to half push the shutter button to release the auto-focus.
Posted on Jan 04, 2007
SOURCE:
Took pictures of sons prom and pictures are blurry blown up, why??? I believe I shot them in sports mode....
Sports mode is meant for constant or fast movement. Its used mainly for sporting events.
The mode you should keep it in is Auto. In this mode you will see that there will be no blurry pics.
May 29, 2010 | Canon PowerShot S3 IS Digital Camera
My camera was dropped, and the screen adn pictures are all blurry
Try going to a camera center. They have the expertise on that matter. They can also tell you to how much is needed to get it fixed.
May 02, 2009 | Kodak EasyShare Z812 IS Digital Camera
Fuji s5000 overexposing pictures
try setting it to auto mode and see if it is ok
otherwise
they are not over exposed actually they have CCD HR problem ur CCD is having fault as 1000's have the same fault u will get pink shades in white and then later it will stop working u have to arrange for ccd change go to fuji service centre
Feb 19, 2009 | Fuji FinePix S5000 Digital Camera
Blurry pictrues in coolpix s51 after droping it
Send the camera to the camera doctor. Your focusing drive has been knocked out of alignment. Due to the impact damage, there might be more problems than just the focusing.
http://www.cameradr.com/
He is a friend of mine, he can fix your camera cheaper than sending it to Nikon and probably faster too.
Nate
Jan 08, 2009 | Nikon Coolpix S51c Digital Camera
Camera will not work
Using the wrong cable can certainly damage a camera.
You don't say what "inoperable" means. I have sold and serviced many digital camera over the years. Dropping a camera will often result in damage to the lens assembly causing blurry/distorted pictures or the lens will not extend or close.
If the camera is completely dead or fails to boot then you probably used the wrong cable or connected it incorrectly and fried the internal electronics. This particular Gateway/Samsung camera can be fried if you connect or disconnect the USB cable while the camera is power on.
Sounds like you owe your friend a new camera.
Jan 03, 2009 | Gateway DC-M40 Digital Camera
Camera problems
I have the same problem. i dropped it once and now every time i take a picture its all blurry. what can i do???
Oct 13, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Blurry camera screen
If the pictures are blurry, you probably damaged the lens with the drop. You will have to send the camera to the factory service to replace the lens unit, if it is not serviceable.
If you drop a camera this is not normally covered by the warranty. You may find it cheaper to replace the camera than have any major service done to it.
Jerry G.
Apr 27, 2008 | Cameras
Fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
Blurry screen on dig. camera
Same problem here any razon or fix yet?
Feb 25, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Fuji FinePix A345 Digital Camera Logo
310 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
