Question about HP Compaq Presario R4000 Notebook
Presario R4000 Keyboard removal
I have a small computer repair shop next to a large University, so I'm pretty familiar with Laptop repair. I an attempting to replace a keyboard on a Presario R4000 notebook. The problem is, I can't find how to remove the old one. I have the "control panel" off, all the screws out and the panel is loose in all areas except the very center where the power button is. Something is holding it there and of course, I don't want to force it and damage the plastic panel. Any suggestions will be appreciated!
  • 1 more comment
  • Chuck Musky
    Chuck Musky Nov 02, 2006
    Thank you for the response,
    It might be, although I don't see any. I am having problems with getting the "bezel" off so that I can get to the keyboard screws. The Bezel unscrews from underneath the laptop, and I have all the screws out but the plastic bezel is still attached somehow at the middle.
  • ctmom Mar 17, 2008
    A similar problem: Bought new keyboard to replace damaged one in Compaq Presario R3000 and can't figure out how to remove old keyboard. Saw a post online that said it was simply one screw in the middle of the back and some locking clips behind the function keys but didn't want to force anything. Any help would be appreciated.
  • manderlyh Feb 21, 2009
    I cannot get the keyboard cover to release about where the word "Presario" is--near the wireless internet button.
    I also don't want to ruin my computer! Help!
  • 3 Answers
The R4000 series bezel has a tiny tab on the bottom (keyboard) edge in the middle. You need to release the bezel from the hinge covers and pull/push towards the keyboard. this will release the tab.
Michael Neill
Posted on Nov 21, 2007
    Scholar:
  • 148 Answers
Is this one of the keyboards that has the little plastic tabs that are springloaded holding it in at the top?
Posted on Nov 02, 2006
SOURCE:
Installing XP SP2 on Compaq Presario R4000, after
Run a HDD Test
Restart Computer -> Immediately keep tapping F10 Key which is on 1st row of Keyboard
Go to diagnostics with your arrow keys
Go to Primary HDD Test -> Press Enter ->
See the Test result
If Fail then Contact HP for Replacement of HDD or Service
Jun 01, 2010 | HP Compaq Presario R4000 Notebook
Why does my Compaq laptop keyboard free up and not work? My laptop keyboard will not work, but the mouse will. i have to use an external keyboard.
You may try to update the driver software to see if works. Please take it to the repair shop to check if it is defective. If you need a new HP Compaq Presario R3000 keyboard?¼Œ you may go to http://www.newlaptopkeyboard.com to order a new one.
Feb 17, 2010 | HP Laptop Keyboard for HP Compaq Presario...
Problem with compaq presario r4000 constant beeping no keyboard
Need to know the number of beeps. They're called beep codes. This page lists some of the Compaq beep codes and what they mean.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Nov 06, 2009 | HP Compaq Presario R4000 Notebook
SATA 2.5 connectors different than current Presario R4000 laptop
It seems that your notebook does not have sata connection to Hard drive. Your harddrive is IDE connection. Sorry but you can't use SATA on this laptop.
Oct 22, 2009 | HP Compaq Presario R4000 Notebook
Replacing the keyboard
your only supposed to pull the hinge out carefully a small amount so the flex cable comes loose, then insert the new keyboards connector there and push them back into place. Its pretty much the same thing in all brands of laptops.
if you have broken the connector, you will probably be looking at buying a new motherboard unless you find someone to replace the broken connector.
Oct 11, 2009 | HP Compaq Presario R4000 Notebook
Compaq Presario R4000 looses video and freezes after a while
The problem you describe can be caused by two different things. The two are not related to each other in any way.
The first, which is more common on desktop computers than laptop computers, is a thermal problem. The video chipset is overheating and causing a shutdown of the video. It is possible that this overheating is actually the cpu, but I don't think so, based on your description.
The second is the video power inverter chip. The power needed to keep the lcd screen lit up on a laptop is considerably more than what is needed to run the laptop itself. For this reason, a small power inverter chip is installed on laptops. It is usually found under the plastic bezal that surrounds the screen, and usually on the bottom. When this chip goes bad, the symptoms are as you have described.
Here's a couple things you can do before seeing a technician or teaching yourself to take apart your laptop. Plug in a different monitor; an external monitor and restart your computer. You should have a function option that will let you see two monitors at once. (that's the fn key, usually in the lower left of your keyboard). With two monitors showing exactly the same pictures, see if you can recreate your symptom.
If the problem is in the power inverter chip, the external monitor should remain on when the lcd monitor goes black.
If the problem is inside your computer (video or cpu overheating) then both monitors will go off.
good luck
tony
Jun 17, 2009 | HP Compaq Presario R4000 Notebook
KEYBOARD DRIVER FOR COMPAQ R4000
There is no driver from Compaq because it just uses a standard driver from the operating system.
Try removing the keyboard from the device manager.
Then restarting the computer.
Let me know what happens.
Feb 27, 2009 | HP Compaq Presario R4000 Notebook
Need to replace screen on presario r4000. do I remove bezel and 'POP' screen out ? is it that easy? thanks Ty
it's not safe to do that alone.
It's LCD, you must not touch it.
It's impossible to replace alone.
If your laptop still under warranty, send back to the warranty.
They will replace it for it.
If not, send to any computer shop, they will know how to repair it.
LCD is different with a normal monitor, you shouldn't touch anything on it. It's very sensitive.
Aug 24, 2008 | Compaq Computers & Internet
Keyboard replacement on an HP 8333 Laptop?
If you look on Google, there are sites that have step by step instructions on how to do it.
Jun 14, 2008 | HP Laptop Keyboard for HP Compaq Presario...
No power in compaq presario R4000
that happens to me all the time too. it will randomly shut off and i wont be able to get it on again till a day or two later
May 15, 2008 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
771 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
