Question about Sony PFM-50C1 50 in. Plasma HDTV
Vertical Black line on display
My Sony PFM-50C1 plasma display has a 1-inch wide vertical black line that runs from the top of the screen to the middle, about 8-inches from the right edge of the display. The authorized Sony technician who came to look at it referred me to the manufacturer's repair facility in San Diego. Since the warranty has expired, it will cost me $1100 for round trip shipping to the Sony facility plus whatever the repair costs might be. Do I have any good options besides junking the unit? My PFM-50C1 has two vertical black strips from top to middle at the left top corner. I exchanged the circuit board for this area with the one at the right bottom to see if the problem is with the circuit board. The black strips are still there and display at right bottom is ok. So the circuit board is ok. Where I should look now? Please advise. Thanks.
    President:
  • 2,712 Answers
Have you checked the cable running from the circuit board to the screen?
Posted on Nov 10, 2008
  • Swilin Sampson
    Swilin Sampson Nov 10, 2008
    No. if the vertical amp has failed, then you would get a horizontal black line and vice-versa.
    Genius:
  • 1,550 Answers
Regarding the two vertical lines
It seems that vertical IC is damaged .
You need to replace them .
2 Suggested Answers
JoeO700
  • 80 Answers
SOURCE: Vertical Black line on display
Rakesh, You have a "dual scan" panel, this is why the line only decends down the screen half-way. This could be a connection problem on the buffer board which causes loss of the drive signal only to that part of the display which it is connected to. The vertical address buffer will be located on the top rear of the display, use great caution in inspecting these cables and connectors. If the integrity of the cable and connector is good the panel itself may be bad due to the drive IC being located on the ribbon cable attached to the panel body. this is better known as COF or, chip-on-film technology. I hope this helps you. Good luck. Joe Weibel CustomElectronics.Org
Posted on Apr 24, 2007
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Sony PFM 42V1 Vertical black line
you have a bad lcd panel call sony they may help
Jul 02, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
I got white vertical line running down a plasma display panel . they are close together that you cant even see on that side of the tv. on a closer inspection they are blue-green-red-blue-green-.... but...
A vertical line running down a plasma display can be caused by :
faulty buffer module.
Fauly sustain card.
Faulty plasma display.
Try unplugging power cable and see if this helps, if it does not , then you will need to call a technician.
In that case call the support number listed on your owner manual.
If warranty has expired, ask for a warranty extension, if available. this is cheaper than repair cost, and will cover the repair.
Jan 04, 2009 | Sony PFM-50C1 50 in. Plasma HDTV
Sony Plasma PFM 50 ci black screen
. Check blink of leds
check the 5 v control voltage.
check Ysus and Zsus board.
check Voltage sc, Vs and Voltage a .
Yareth De Matos - Venezuelan -
Mar 28, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Black Vertical line about an inch wide right of middle - PFM-42V1 Sony
I have exactly same problem. If you find solution. please email me at tpobandith@gmail.com. I greatly approciated. I'll do the same if I found solution.
Thanks,
Mar 21, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Sony PFM-50C1 Fuzzy Dim Display
Just want to let you know that the problem you are having is a bad X board. This board may not be available from Sony, because it is sold as part of the panel
Best regards
CircuitCity
Sep 28, 2007 | Sony PFM-50C1 50 in. Plasma HDTV
Jan 28, 2007 | Sony PFM-50C1 50 in. Plasma HDTV
Sony PFM-50C1 50 in. Plasma HDTV Logo
269 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
