MAytag Neptune Drains Slow
My Maytag Neptune Drains very slow. Replaced Pump and it has not corrected the problem
How do you get to the stopper valvue?
Posted on Feb 28, 2010
    President:
  • Washing Mach... Master
  • 2,651 Answers
Perhaps there a clog in the draiin line or ive even sen where a coin will lodge itself in the opening of the hose in such a way that it acts a s a stopper valve rotating open and closed, be sure to look down / blow the lines clear
Posted on Nov 10, 2008
Maytag washer pav5157aww
Your pump is probably stiff. Bearing is going out.If the pump is ok I would look at possibly replacing the thrust bearing. Their could be something between tubs.
May 15, 2013 | Maytag Neptune Washer
F 21 showed on screen and will not tumble or drain
The error code is a slow drain..Which means the drain pump mis blocked or damaged..Most of the time all you need to do is clean the pump filter out.
Nov 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load washer won't drain water
maytag performance series washer front load drains very,very slow
Apr 07, 2012 | Maytag Washing Machines
My washer has a uC fault. I replaced the tub sensor but it still alarms after spinning. The water drains, the tub spins slow, then alarms uC. Thank you for your help.
Dave,
Sorry you replaced the TDS.
Google Neptune TL Washer FAV6800AWW that's the Sticky for your machine type. The 5th post down you will find notes to repair.
Post a new thread in that DIY forum not the Stick if you need additional help.
Feb 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
No spin
If anyhow the drain pump is blocked the spinning will be blocked. Check for a forrign object in the drain pump. If you can feel/hear it buzz (very quietly) while it should be pumping out it might be jammed up with something. That however is kind of rare with the angled tub the Neptune uses.
Are you sure the machine is actually not pumping out, or is it possible its just turning off in the rinses?
Reason I'm asking is the control will shut the machine down if its taking too long to fill up. Many times it will fill fine for the wash fill, but because the rinse takes twice the ammount of water it activates the system and shuts down while its half way filled. Look for a slow cold water fill for that problem.
Is the door locking in the spin? One very common problem on the older 3000 and 4000 series machines is the R11 resistor on the machine control board bruning out leaving the door lock inoperative. If the door won't lock, it won't spin. I do believe, however, the machine will still pump out. But many times what happens is the pump removes all the standing water, but without spinning everything in the tub stays soaked. The saturated clothing drains the water out and then leaves a few inches in the bottom of the tub.
If you have the newer style Neptune (with the control panel on the front of the machine) only the top paragraph applies.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Jul 09, 2009 | Maytag Bravos MTW6600T Top Load Washer
Maytag mah4000aww wont stop running.
It sounds like your timer needs to be replaced. The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
Jun 07, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag mah4000aww trys to spin shakes and stops
there are off balance switchs on the tub that will turn it off But if the pump sump is full it will pump slow and throw it off balance so check to see how well and fast it is pumping the water out
Nov 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
