Escient dvdm-300 flashing red not starting
My escient dvdm-300m stopped booting up a few days ago. I have tried the 4 sec reset and unplugging power (for more than an hour). Still flashing red. Any other known way to reset the unit?
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
  • 1314 Answers
SOURCE: Dryer starts then stops after a few seconds.
thank you ill get back to you after reading the tech manual shortly
Posted on Jan 17, 2008
SOURCE: se-d1 will not boot
escient music server...light blinking red...
cant turn on system...
tried resetting...nothing
tried turning system off..for a hour or two...nothing..
juse blinks will not respond to anything...
any ideas.
Posted on Nov 11, 2008
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ gsierra11@yahoo.com
hope this helps.
Posted on Feb 19, 2009
  • 47 Answers
SOURCE: Yamaha RX-V750 wont power up
Check the fuse. You might have had a power surge which blew a fuse. If not, check the fuse for the socket. Reset the fuses for that socket. If it still doesn't work, it sounds like the internal boards got fried, or the power supply got fried. The power supply is replaceable, but we don't know if it is the power supply. To check, connect a voltage meter to the power supply.
Something like this happened to me. I found a new kenwood stereo next to the dumpsters, stickers and all still on it, plugged it in, it worked, shut it off to plug in a speaker, didn't turn back on, months later after leaving it plugged in, turned on, I used it, then shut it off for the night, in the morning the standby light was still on, tried turning it on, but it wouldn't for some reason, unplugged it, then the light wouldn't come on, it was once again sitting on a shelf as a paperweight, one day it randomly came on again, and now it 100% works, and I use it as an amp for my RE audio subwoofer, and its worked great since! The reason this kinda applies to you is because its kinda simmilar what happened to you. Just leave it plugged in, and maybe sometime you will walk by it noticing it works.
Posted on Oct 11, 2009
Testimonial: "Thanks for the advice"
Blue light flashing
Do a hard reset,usually there is a button on the back of the router.With power plugged in,press and hold reset button 15 sec. then without releasing button remove power plug and hold an additional 15 sec.,then plug power cord back in and hold an additional 15 sec. After that release the reset button and it should reset to default.You may need to do this a few times but it should solve your issue.
Apr 16, 2014 | Belkin Computers & Internet
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Park lights and dash lights won't stop flashing
There is a small black box under dash by steering column that has a little red button on it. Push that button and it will reset the alarm. Whenever the power is removed from the system it will trigger that alarm and flash your lights. Easy quick fix. Box is about 4" x4" and just to the left of the column. Good luck and have a great day.
Mar 14, 2009 | 1998 Subaru Legacy
Se-d1 will not boot
any ideas.
Jun 28, 2008 | Digital Products Escient SE-D1 FireBall...
PLEASE HELP QUICK! 36" Sony blinking 4 red times
probably this is the small mailfunction,probably some contacts,but you probably not a qualified to do this repair ,so please call a service man
Feb 07, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
36" Sony Trinitron blinking red 4 times-PLEASE HELP QUICK!
Sounds like a typical high-voltage failure. Could easily cost another $300 to have it fixed. If it is less than about 6 years old I'd say it was worth fixing. If you want to DIY, then pull all the electronics out (label all the connections) and send it all to either Module Exchange at 972-298-1212 or PTS Electronics 800-844-7871
Feb 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
HP Media center 1170m
did you checked the ram just clean and fix it again. bye
Oct 01, 2007 | HP Media Center m1170n Photosmart PC...
140 people viewed this question
 Grubhead
Grubhead
