Question about Philips SA6025 Digital Media Player
Device manager's recognition problem of my operating system
I tried to setup device manager for my player to my computer but when setup starts, it does not work. I have fully updated XP x64 operating system. the setup manager of the device manager says I need service pack 2 or higher, but I have it so what can I do? I want to update firmware of my player...
  • swati2801 Mar 30, 2009
    i want download songs in my Gogear player but when ever i connect with PC its not accesseing only.Itried to download software alaso but its not run on my PC.pls help me out for this.
  • 8,596 Answers
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Mar 20, 2009
Why the windows7 cannot recognize the usb cable device of psvita
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Oct 07, 2012 | Microsoft Windows 7 Home Premium 64BIT...
Some USB that are attach to my pc are not recognized.
Method 1: Initiate recognition of the USB device by using Device Manager loadTOCNode(2, 'workaround'); To initiate recognition of the USB device by using Device Manager, follow these steps:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  4. Close the Device Manager window.
If this method resolves the issue, you are finished.
If this method does not resolve the issue, go to method 2. uparrow.gifBack to the top Method 2: Disable power management of the USB hub loadTOCNode(2, 'workaround'); Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
  8. Close the Device Manager window.
If this method does not resolve the issue, go to method 3. uparrow.gifBack to the top Method 3: Restart the computer loadTOCNode(2, 'workaround'); To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
Aug 14, 2011 | Computers & Internet
USB port not reconizing
The time delay depends on the following factors:
  • Host controller hardware
  • Attached hubs
  • Attached devices
  • USB driver versions
  • Support for USB 2.0
  • Additional system hardware or configurations that may change the timing
Method 1: Initiate recognition of the USB device by using Device ManagerTo initiate recognition of the USB device by using Device Manager, follow these steps:
Method 2: Restart the computer To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
If this method does not resolve the issue, you might want to review the articles in the "Similar Problems and Solutions" section, or contact Support. For information about how to contact Support, visit the following Microsoft Web site: http://support.microsoft.com/contactus (http://support.microsoft.com/contactus)
Dec 22, 2010 | FireLite (USBFLB80) Hard Drive
My coby m600-4g mp3 player is connected to my computer through a usb port how ever my computer is not picking up the device. How do i get my computer to recognize the device as removable media?
You can install Coby Media Manager from the manufacturer.
Go to cobyusa.com
Select Support
Select the download Media Manager fix for MP822
Follow up the installation of Coby Media Manager for the operating system on your computer.
After the installation, run Coby Media Manager.
In Coby Media Manager, In the page top select: Tools > Device Manager...
From the Devices list select the matching MP600 AC or AL version.
Add >>
Select OK to setup the matching player as Favorite device.
In the Device Manager under Configure... or Device Configuration you
can choose between manual or automatic setup for synchronization
and the output file format can be changed.
Apr 23, 2010 | Coby MP-610 MP3 Player
This came with no software and i cannot seem to put any music or video on this mp3 player why
When not having the installation CD at your disposal, for support select
MP3 & Portable > MP3 & MP4 Players > MPC7085 in this page:
http://www.cobyusa.com/?p=doc
Start with the MP-C7085 setup guide:
http://www.cobyusa.com/files/setupguide/MPC7085_SG.pdf
More information about the device in MP-C7085 manual:
http://www.cobyusa.com/files/manuals/MPC7085_MN.pdf
Software Coby Media Manager for the computer:
When running Operating System Windows 2000/XP/Vista:
http://www.digdash.biz/product/coby/coby_media_manager/install/coby-mediamanager-2009b0924.exe
When running MAC OS X10.4 or later:
http://www.digdash.biz/product/coby/coby_media_manager/install/coby-mediamanager-2009b0814.dmg
For a download right click the matching software and select "Save Target As..." to a location on the computer. Run the software by double clicking it.
When running Coby Media Manager select Tools > Device Manager...
to select the MP-C7085 from the list, Add and OK for this player setup.
Need more help ? Just post a comment.
Jan 04, 2010 | Coby MP-C7085 MP3 Player
Can't use cd/dvd player - computer doesn't recognize it
try to boot the computer using cd. like you trying to install windows. if it read the cd to get into the windows setup, then cd drive is good.
1st make sure you set the option boot from cd first in the bios.
2nd place a windows setup into the drive.
3rd save and exit the bios.
4th if it ask you to press any key to enter setup then the cd drive is good.
maybe u have a windows problem, try to reinstall windows, that the easy way.
Aug 28, 2009 | HP Pavilion dv2000t Notebook
Speech recognition
Reinstall Asus sound card drivers from the setup cd..
Jul 11, 2009 | Computers & Internet
Erasing music from mp3 player
get pc with usb 2.0 port, and at least win 2000 professional on it
get mp3 player
get install cd for mp3 player (if you have one)
boot up, plug in player, wait for recognition by win2K or above, then treat as if it was an usb-stick or
external harddisk: erase the files you want or format it all to have it blank, copy new files
if not, run hardware detection via device manager, if windows does detect unknown device,
let it find driver from the hardddisk or win setup-cd/dvd, install, try to find as harddisk
or run install from mp3-related cd, choose the right driver fitting your operation system, install
remove mp3-player, reboot, repug, win should now find it automatically!
now erase the music files(mp3's) on your player and/or copy new ones, unplug,
put in fresh battery and enjoy!
Jun 18, 2009 | Audio Players & Recorders
I have a sansa clip media player and my computer does not recognize it how can i fix this
You can get any missing software from Sandisk's website if you have lost your installation CD.
Another way to force recognition:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Dec 27, 2008 | SanDisk Sansa Clip MP3 Player
Opal mp3 player m4002
What version of windows media player do you have? if you dont have the most recent one try to upgrade it to WMP11...if that doesnt solve the problems unintall the device from device manager and try to reinstall back again..the device will be listed under device manager with exclamation mark if it doesnt install properly...what operating system do you have? do you have service pack 2?
Jan 04, 2008 | RCA OPAL M4001 MP3 Player
Philips SA6025 Digital Media Player Logo
174 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
