Question about Dell 922 All-In-One InkJet Printer
No paper feed
When trying to print the paper doesn't feed at all - i was on line with the tech at dell. i have a roller problem but my warranty was up a year ago. does anyone know where i can get rollers for this machine.??
  • chris200959 Jul 01, 2008
    the rollers move but the paper is not fed through the printer unless you push it throughby hand, it as if the rollers don't grip the paper
  • Anonymous Jul 02, 2008
    I have the same problem. I was trying to see if it was cheaper to buy rollers or or a new printer!!
    Ree Coleman
    President:
  • Dell Master
  • 2,022 Answers
Spare parts are not easily available it is bettre to give service peronnel and they will arrang and fix the problem. bye
Posted on Sep 24, 2007
I have two 1710n dell printers that when they print, the lines ar curved and non of the words are in a straight row
If both of the printers have seperate toner and drum cartridges, then it is probably a feed roller issue ( one side is pulling the paper more than the other, causing a curved line ). One trick to try would be to print a page, and pull the power cord halfway through the print. Open the printer and remove the paper and drum and toner and look on the drum. If the latent text is curved on the drum, Then replace both. It is odd that you have two printers that are having the same issue though, especially if you have two drum and toner units. Also, check to make sure that the paper is seated properly in the paper tray, if there is too much play around the paper, the printer may not feed the paper properly. With physical access to the printers, a tech should be able to figure out the problem fairly quickly.
Sep 29, 2010 | Dell 1710 Laser Printer
Document won't print, but it sounds like it is
Make sure the paper feed is full of fresh paper. Print something, and watch where the paper feeds into the machine. If the feed roller actuates and tries to pickup the paper but doesn't, you may need to clean the pickup roller with distilled water and a qtip. If it still doesn't pickup the paper, repair it under warranty with canon or replace it if not under warranty.
Sep 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Dell 1720dn laser printer
If the paper intake rollers are slick and grab paper on an angle, the feed causes the paper to move off center. Rubbing the rollers with a cloth and rubbing alcohol will clean them. Slightly rubbing the entire roller with a fine abrasive material can help with the paper path issue.
Feb 07, 2018 | Dell 1720dn Laser Printer
I have a Dell all in one 922 printer When I try
If your device is out of warranty, I'd suggest to clean the rollers again completely. What I mean is to remove the scanner lid and back cover, then clean all of the rubber rollers gently with alcohol and swabs.
Jun 14, 2009 | Dell 922 All-In-One InkJet Printer
Distorted printed documents
Try this steps first and these steps first :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 17, 2009 | Dell Photo 964 All-In-One InkJet Printer
Paper jam..cartridge back and forth
hi
This clearly indicates that problem is with the rollers in the paper feed tray..to clear the obstruction-fold a sheet of paper 3-4 times lenghtwise to make it thick..insert this into the paper feed tray,behind the rollers-move it left right a couple of times....repeat this a couple of times-if no go...call tech support..printer would be replaced if in warranty...good luck
Jan 24, 2009 | Office Equipment & Supplies
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
3100cn not printing
with the access door for the paper open, slide the paper in, try to print. If the feed roller turns but does not pick up paper then the feed roller is worn beyond use and must be replaced.
Sep 23, 2008 | Dell 3100cn Laser Printer
Paper Jam
We need to the model/make to help you
but using some detective skills I've decided you are using a HP machine
Yup Dirty damaged worn feed roller but what model machine is it they are all different but pull out tray 2 cassette all the way and look in, there is probally a cylinder like rubber roller 5cm wide front centre of where cassette slides in, there might be roller on the cassette too at the front center as well.
Most modern printers feed rollers just slide off after lifting small plastic tabs on them and gently pulling, feed rollers are available but you can sometimes also get results by cleaning them with a dash of metho or water on a rag.
If paper feeds 2wo sheets at once then you need to change the seperation pad/roller too.
Nov 01, 2007 | Dell W5300N Laser Printer
Paper problem
from what it sounds like you have the same problem i do. being on the phone with a tech at dell i was told it is a roller problem. suggestion from tech: time to buy a new one - as they do not fix these kinds of problems but if under warranty they will replace for free. hope you are still under warranty, good luck.......
Sep 27, 2006 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
74 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
