Question about Electrolux Kitchen Ranges
Electrolux electric cook top EHC614W*31, when you turn any of the the elements on , not only the element gets hot but the whole cooktop. It's so hot that it burns you if you touch it. regards John
  • johnwilliams Nov 10, 2008
    The problem has been since new
    Scholar:
  • 112 Answers
This isn't something that you can do that much about. If it's new, I would contact the company and explain the situation and see what they say. It could be that one of the heating elements is out-of-line, and is heating up the rest of the stove top, but it may be poor design or manufacturer error. Even if it is not new, you will still probably have to call a repair man. Based on the information given, you can't really do much.
Posted on Nov 10, 2008
    Brigadier General:
  • 6,966 Answers
Initially, may I inquire if there was anything out of the ordinary prior to the problem such as water spillage, recent cleaning, power outages/interruptions? Offhand, other than faulty or corroded temperature limiter, their would be no direct cause for the cooktop to heat up as you have described.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 14, 2008
    Hi again,
    Any development so far?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Hi was there any spillage b4 then? or the switches has being connected  in series insted of parallel & this will increas the heat wattage as each plate will be delivering its maximum design wattage. open & separate this plates & switches & conect each plate to its switch & connected peach swites parallel
    Sergeant:
    Champion:
  • 435 Answers
Hi, Was it all of a sudden or was it there since you bought it ?
I know some of these models have some cooling system to cool the surroundings but not sure about his specific model.
If it was all of a sudden, let me know.
E 35 diplay on electrolux e30ec70fss cook top
Hey Syl20 Bel, thank you for your post!
Based off the information you have provided your Electrolux cooktop is displaying an error code of "E 35". The error code means that the cooking zones could have a low voltage. This could be an issue within the filter board or power supply. You may want to seek help from a professional technician to help verify which component that would need to be replaced. A technician will have the appropriate tools needed to test each component as well as the knowledge to properly disassemble the cooktop. I hope this information is helpful to you. -Matt
Mar 07, 2016 | Electrolux E30EC70FSS Cooking Products :...
Double ring burner won't light up.
the outer element may be broken if the center one is the only one getting hot
Apr 07, 2010 | Electrolux 23 in. EHD6670P Electric...
Opening the cook top in a Whirlpool electric range
The cooktop on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the frotn edge of the cooktop. You will need to open the oven door to see them. Just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. The elements are fragile.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
If you have any questions about this repair, please let me know. You can reference searspartdirect.com for some helpful exploded view diagrams of you range for assistance if you need it. I hope you find this information helpful.
Nov 12, 2009 | Whirlpool RF378 Electric Kitchen Range
ELEMENT WONT SHUT OFF
Sounds like that specific element has shorted to ground inside it's sheath. You'll probably find the element does not get as hot as it normally would.
A fuse will not blow, or breaker not throw, because of the point in the element that the element has grounded.
Elements are available from a number of resources.
A way to test if the element is shorted to ground:
Tools needed -
Ohmeter
1)Disconnect power from the appliance
2) Remove the element (Sometimes they are plugged in, sometimes the wires screw onto the ends of the element.
3) Set the Ohmeter to Rx1000 or more.
4) Measure the resistance between the outside metal sheath, and either of the two power connection points on either end of the element. Under any condition, you should not get a reading. If you do, the element is bad, and you need to get a new one. They are not repairable.
5) Re-install in the reverse removed.
6) Check all connections are clean and all is re-assembled as you originally found it.
7) Turn on power and check if element comes on.
It is unlikely the problem is with the control, but it is a possibility. Give me more info about the cook-top (make, model) so I can investigate further.
Jan 14, 2009 | KitchenAid 32 in. KECC502 Electric Cooktop
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Cooking element
Hello
If the grilling elements does not get hot enough, then the main reasons for that are:
Escessive air movement across the grill.
Surface controls may not be properly set.
and the voltage maybe low.
But if is not getting hot at all then you can check by exchainging the elements to see if it is the element itself, and if it is the element then you will need to replace it.
I hope this help!!
If you need to replace it I know a place that are very cheap for Jenn-Air parts and super fast delivery...Let me know.
Eddie rentas
Tupper Lake
Jul 13, 2008 | Jenn-Air JED7430 Electric Cooktop
Both burners turn on when only one is needed
I just had the same problem- when I replaced the whole cartridge.
I repalced the infinite switch- do the one that gets the hottest- or do both.
It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
good luck
Jun 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Electric Cooktop Heating Elements Get Hot, Turn Off, Get Hot, Turn Off
no they are made to cycle that way they are halagen and cycle with a sensor dont work like the old coil ones do enegey efficent and hotter than old coils dont use them without a pan on them to reflect heat back to the sensor to prolong their life
Dec 29, 2007 | Viking 31 in. VGSU101 Gas Cooktop
Hot Surface Light stays on
Our success has been to heat the elements to hot for about 5 minutes. Then let cool to reset temp sensor.
Can cause the problem by turning a burner on for a short period of time
Dec 16, 2007 | Whirlpool GJC3034 Electric Cooktop
Kitchen Ranges Logo
29 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
