USB 2.5 inch HD does not show on PC
My HD does not show on the pc when plugged in a USB port, but the memory stick does shows. Is this HD damage or is it posiibly a casing problem only? I have too much valuable stuff safed like memory photos of places visited. Being from RSA (ZA) its diffcult to travel and re-capture those photos. Please help me on a solution or temporary retrieving the data.
  • 44 Answers
Data recovery software can only retrieve data if the HDD shows in windows. Some disks may not show in My Computer(if corrupted). Another way of checking if the HDD is being detected by windows is using disk management. Click Start,then run, then type compmgmt.msc. Click on Disk Management when the Computer Management box opens. If you HDD is showed among the list of drives there is a possibility of getting our data.If not you need advance data recovery where the HDD has to be physically taken apart.Let me know what your findings are.
Posted on Nov 10, 2008
How to use Toshiba Media Player
Is the USB drive able to be read on your PC / Laptop ?
It COULD be that the USB drive has been 'Formatted' (made ready to receive files) but not in the 'FAT32' mode. It WILL say so in your TV manual.
PCs can read all format USB sticks but TVs are fussy and generally only work if the USB stick is formatted 'FAT32' and not 'NTFS' (which it probably is.
1) Put the stick in your PC - right click on it from 'my computer.'
2) Format the USB drive with FAT32,
3) Reload the stick from your PC with the photos.
4) Plug it in your TV.
It will be fine.
Sep 14, 2014 | Toshiba 50L5200 50-inch LED TV
Is ATI Radeon HD 4250 Graphics an OpenCL graphics card compatible with FInal Cut Pro X?
As "Final Cut Pro X" is an Apple program, you need to make sure you are using an "Apple" Operating System. It will not run on Windows.
Mar 27, 2012 | Computers & Internet
Not detected
1stly try the Kingstone in another PC - if it works in another PC you have 1 of 4 problems:
1] You are using a very old version of Windows and therefore would require drivers for the memory stick. (i.e. Windows 95 or Windows 98)
2] Your USB ports are faulty - try the ports at the back of the PC instead of the ones in the front if you have not done so already
3] There is a virus on your memory stick and it is attempting to load an executable file when u plug it in and that is causing it to fail.
4] It is detecting fine but you cant read it because the FAT (File allocation table) is damaged in which case it will need to be formatted.
I will need some more info though - for example:
Does windows say "Hardware detected" when u plug it in?
Are you getting any lights flashing on the memory stick?
What do you see when u click on my computer? Does is show up at all but u just cant open it?
Good Luck
Feb 04, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Please can you send me detailed instructions on how to use a kingston usb memory stick
The memory stick becomes another drive, when plugged into the USB port. Some sticks have a write protect, which is a teeny tiny switch. If the switch is in the protect position, you can read but not write any data to the drive. Often the drive will be listed after all of your camera card ports.
To view the drive press and hold the Windows key and press the letter E. and then release both. The available drives should show up there.
Nov 17, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I used this memory stick on my old PC at home and it was wrking okay. When i put it into the usb port it showed up ad removable E. Now I have upgraded my pc to a laptop it doesent recognise the stick....
I assume when you say "memory stick" that you mean a USB memory stick rather than a Sony memory stick.
You should try it in another USB port (if ther is one on your laptop). If that doesn't work, then try it in another PC - if it doesn't work in another PC either, then it is likely that the memory device is at fault, otherwise. If it works fine on another PC, then it is likely that it is the USB port on your new laptop that is at fault in some manner.
If you have another USB device you can use (anything will do - a mouse, webcam, etc), try it in the port you tried the memory stick in. If nothing happens, then in all likeleyhood, the USB port is at fault. If the other device works, then it is probably the USB memory device that is faulty.
If the device works in another PC, try reformatting it as FAT file system on that PC, and see if you can then see it in your new laptop.
Oct 21, 2010 | Office Equipment & Supplies
My light is on and a buzz sound is heardwhich stops after a minute and no data is displayed
You do not say whether the HDD ever worked.
If it did, and stopped, chances are that the internal HD is damaged, or the motor performances degraded and it now requiring a higher current than the USB port can deliver.
Try plugging it on a different USB port or, better yet, into an externally powered USB hub. There are also special cables which plug two USB ports into one and deliver double current to the appliance.
As a last resort, it might be possible to recover it by extracting it from its enclosure and connecting to a desktop PC via a 3.5-to-2.5 inch HD adapter.
In all cases, unless it never worked on that PC (which means that the problem might be in that PC's USB port), I'd strongly suggest to back up all data on another disk.
Oct 26, 2009 | Seagate Free Agent Go Small 12 GB USB...
Plugged in 1gb flash stick pc powered down now shows no sign of life what so ever tried 2 more power supplies and new cmos battery still dead help please
Did the system power down as soon as you plugged it in? Or just at the next reboot some time later? It is possible there was a short at the usb port. It is unusual to burn out the mobo, since most usb ports are fused.
Unplug all peripherals, drives and cards, then try to roboot just the motherboard. If that's ok, the plug things back in, one by one and boot each time.
Also, if the usb jack is damaged somehow, unplug it from the motherboard headers and try to boot.
Apr 23, 2008 | Computers & Internet
Aspire 3610 USB ports
Device manager shows the USB port if they are attached to you notebook. And in your case they are attached. So it will show it. Now in your case the problem is in your USB. Get it changed. If it is in warranty peroid then dont u take any risk. Let it be replaced. Or give your notebook in warranty period to the company from which you bought.
Sep 26, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
