Question about Hamilton Beach BrewStation 47665
Hamilton Beach Brew Station 47665
I have lost the user's manual for this model. It needs cleaning to get rid of mineral deposits. This brewstations leaks coffee out on the counter. What can be done to solve this problem? Is this a problem caused by mineral deposits from hard water or is something else the cause?
  • 2 more comments
  • Jesus Girl Jan 01, 2009
    I have the same problem. I tried to order the cleaner and it has been on back-order since April 2008. Let me know if you find a solution. My manual says do not use vinegar.
  • bethjersey Jan 18, 2009
    After I cleaned my coffee pot it started leaking. The leak appears to be coming from the heat plate area. All the screws are tight. The machine is just under a year old.
  • Anonymous Feb 27, 2009
    `coffee leaks from the valve the coffee comes out of the rubber valve
    where can u find valve?
  • Anonymous Mar 17, 2009
    My 47665 leaks also and I believe it is coming from the hot plate area. I took it off and there is a gasket that might need to be replaced. I will try to find a new gasket and if it works I will post it.
  • 8,596 Answers
Here is the link to the manual - for those with leaks, call Hamilton Beach:
http://useandcares.hamiltonbeach.com/files/840156002.pdf
-Tha Mp3 Doctor
Posted on Mar 26, 2009
I had similar problem. i removed screws and rubber seal on tank, and located a hair line crack near rubber seal, a dab of crazy clue seems to have solved this problem for now
Posted on Jun 14, 2009
My 47665 leaked from the hot plate area. Go to an auto parts store and buy the Permatex High-Temp Red RTV Silicone Gasket Maker. Do the following to the bucket... 1.) Take the hot plate & gasket off. 2.) With your finger spread the Permatex on the gasket lip, the inside of the hole & the surface where the hot plate sits (just enough to make a very lite coating). 3.) Wait 5 minutes & install the rubber gasket. 4.) Spread the Permatex on the rest of the rubber gasket (very lite coating). 5.) Wait 5 minutes & install the hot plate (the plate will want to come out, so just push down on it). 6.) Wipe off access Permatex on the outside & inside. 7.) Let it set for at least 12 hours, perk 3 cups of water and wait for Auto-shutoff. 8.) Now go make some coffee that you've been waiting for... LOL
Posted on Feb 10, 2011
How do I get a copy of a manual for a Hamilton Beach Brew Station Deluxe Model #47454 ?
The manual is available on the Hamilton Beach product page: http://www.hamiltonbeach.com/coffee-makers-legacy-products-brewstation-deluxe-12-cup-coffee-maker-47454.html#careguides . (If needed, click on the Use and Care Guides tab.)
The direct link to the Use and Care Manual is http://useandcares.hamiltonbeach.com/files/840160504.pdf . (Note: Adobe Reader or a similar program is needed to read or print the manual.)
I hope this helps.
Feb 24, 2015 | Hamilton Beach Brewstation Brew Station...
Hamilton beach brewstation will not brew
Can you define will not brew? Do you mean no water transfers from the holding tank to the brew carafe? Does coffee not heat up?
Apr 11, 2013 | Hamilton Beach BrewStation 47665
How do I change a filter?
Your Use and Care Manual can be found here:
See illustrated instructions on page 7 for how to change the water filter.
Mar 08, 2011 | Hamilton Beach BrewStation 47665
Brew station is extremely slow, suspect it needs cleaning.
You can run a cup of vinegar through the machine. Run it just as you would making coffee, except without the coffee. Run water through the cycle at least twice to remove sediment and the vinegar. Works like a charm.
Jun 16, 2010 | Hamilton Beach BrewStation Deluxe 47474...
Cln
hi b1johansen,
 cln refers to "Clean"....
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100%satisfied.
Apr 17, 2009 | Hamilton Beach BrewStation 47665
Makes noise but water doesn't come out
you should consider cleaning calc from your boiler( descaling ), and checking the pump presure. i think it will work ok after that.
Apr 02, 2009 | Hamilton Beach BrewStation 47665
Automatic brewing
Here is a link to the manual:
Hold PROG until clock flashes. Continue holding PROG button;
press H and M until the desired
brewing start time is reached.
Press PROG momentarily to
activate automatic brewing.
Mar 25, 2009 | Hamilton Beach BrewStation 47665
I have Brew Station 47665. My coffee tank leaks.
contact 1800-815-8900 give model no. &serial no. under brewmaker bottom they have replacement part & info
47214 brewstation
Feb 07, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Hamilton Beach BrewStation 47665 Logo
1,670 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
