Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Gas stove the burners work but when I open the oven door no flame is present and I do not smell gas. What could be the problem
  • 1,543 Answers
The most common reason for that is that the oven ignitor is bad. Part number WB2X9154.
Posted on Nov 10, 2008
Orange glow after oven burners were lit, thenflames in oven
Sounds like maybe some grease or something had been spilld and then caught on fire while you preheated the oven
Jan 07, 2018 | Kitchen Ranges
I have an old gas stove. No igniter.Lights with pilot light only. Stove top burners work fine.Oven does not ignite. The pilot lite is on.I smell no gas when I turn it on.
Pilot flame has to hit the thermocouple. If pilot is dory flame.will be weak and not reaching the thermocouple that tells the oven there is a flame and opens the burner. If the pilot is strong and no gas to burner than that thermocouple. ( 100% safely valve is worn out) replace that and you are good
Dec 30, 2017 | Kitchen Ranges
My galaxy range model 790.60012604. The oven do not heat up . The element is lite up but the oven burner do not flame up which leaves a gas smell.
You need a new igniter, it may glow, but is probably not drawing the exact amperage required to open the gas valve decisively... You should also check burner tube and orifice for spider webs or other obstructions... Kenmore Range Stove Oven Igniter 316489402
Jul 05, 2016 | Galaxy Kitchen Ranges
Just recently our 10 year old stove started smelling funny only when its on. the burner burns but the flame is yellow and was normally blue. I understand the air fuel mixture could be off, how Do I fix...
Gas flame on all gas appliance should burn clear blue.
Yellow flame means you need to clean the burners.
This applies to stoves, oven, furnaces, water heaters
I did a google search for: clean burners on gas stove.
There was more information and helpful tips on those links than I can honestly repeat here, including how-to videos.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on appliance.
Jan 03, 2011 | Hardware & Accessories
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
Whirpool gas range - propane gas not sure oven is working right
First, the flame should be blue and without much visible yellow. You need to give the gas tube a good cleaning to get out any soot buildup and any partial obstuctions that might be causing the problem. Since you started with a yellow flame and soot, you need to get the burner tubes clean to see if you have resolved the problem after adjusting the regulator and burner valve(s).
You might need to install a different regulator to match the pressure of your gas supply source, as regulators have a specific working range of inlet (supply gas pressure) that they can operate properly at to "regulate" the supply pressure to the stove's needed pressure.
Check your manual and the installation guide to verify what the gas inlet pressure requirements are and check with your gas supplier to see what they are providing you.
To your 2nd question, yes, the gas will cycle on and off when you are using the oven, since the thermostat will call for more heat when needed and shut off the gas/flame once the temperature you set the control at, has been reached. The cycling is a result of the oven trying to maintain the desired temperature for baking.
One reason that you can smell gas when the oven is being used, is because all gas ovens have a surface vent to allow excess heat to escape from the oven compartment, however you should not be smelling raw gas (actually you're smelling the "rotten egg" additive that's put in the gas) all the time, since when the oven is turned on, a small electric ignitor is heated up VERY HOT glowing bright orange inside the oven compartment. Once it's hot enough a sensor opens the gas valve and lets gas into the burner tube to be ignited instantly by the VERY HOT ignitor. It is rare to smell raw gas with this system, but sometimes you'll get a stronger "rotten egg" smell at different times due to the gas company and their system, etc.
As to the gas smell, you should NOT be smelling gas every time the oven cycles on when baking, as a normal ongoing occurrence. During the first few uses, it is normal to smell some gas, but this should go away after a couple of uses. If it doesn't, you should look to make sure the regulator and oven controls are PROPERLY configured and set - Since you've already fiddled with these, it's probably a good idea to have someone from your gas company (or a gas appliance tech) come out and do this. Improper settings can cause some serious problems.
Hope this helps!
Jul 15, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Burner flame shuts off during use and then you smell gas
all ovens, when they reach temperature they go off and on to kip the temperature, but if you smell gas the oven ignitor needs replacing, the ignitor gets red hot to ignite the burner ,but when ignitor does not get hot enough, it will have a delayed, that's the reason you smell gas.
Dec 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
Funny Smell
ALL YOUR FLAMES SHOULD BE CLEAN BLUE FLAMES WITH NO WHITE OR YELLOW TIPS OR FLAMES !!!! YELLOW FLAME = DIRT OR PAINT? WHITE = LACK OF AIR SOUNDS LIKE YOUR STOVE IS NOT GETTING ENOUGH COMBUSTION AIR. INPROPER AIR ADJUSTMENTS OR LACK OF AIR WILL CAUSE A WHITE TIP ON THE FLAME ... THAT IS CARBON-MONIXIDE !!! A CLEAN BLUE FLAME EMITTS CARBON-DIOXIDE AND IS NORMAL. IF YOU USED AN AIR-GUN TO PAINT, CHANCES ARE YOUR BURNERS HAVE A SLIGHT COATING ON THEM AND HOPEFULLY WILL BURN OFF IN TIME. TRY OPENING ALL YOUR DOORS AND WINDOWS IN YOUR HOUSE ... AND TURN ALL BURNERS ON AND LET THEM BURN FOR AN HOUR. DO NOT LKEAVE SIGHT OF THE STOVE, BUT KEEP NEAR A OPEN WINDOW. NOTICE !!! MOST GAS COMPANIES WILL COME OUT AT NO CHARGE TO CHECK GAS, AND FOR CARBON-MONOXIDE.(C0) NOT (CO2).
Apr 28, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
157 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
