Question about Kenmore 62602 Electric Dryer
Dryer timer comes on but with door shut it won't turn on
The dryer was working fine, I put another load in and turned the timer on and shut the door pressed the start button and nothing happened, you could hear the timer running but it wouldn't turn on
  • 5,911 Answers
There are several problems that can cause a dryer not to turn on. The timer running tells me you are getting voltage to the operator console as the timer runs off 220VAC. The motor, however, requires several things to working in order for it to run. The door switch has to be in working order and making contact as the door closes. An easy test is to push in on the door switch with the door open. If the light goes out, the switch is making contact. The following link I'm providing will give you some more pointers on what to troubleshoot next:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Read through the link thoroughly and make sure your dryer vent ducting is clean prior to replacing any failed components. It is essential that a dryer has proper air flow in order to operate efficiently. Some component failures are directly attributed to clogged ducting and will occur again if the problem is not resolved. Read through the section that decribes a dryer that "does not run at all". A common failed item is the thermal FUSE, which can fail due to overheating. If it is blown, it must be replaced. The component is usually white in color and made of plastic. It will be mounted on the blower fan housing inside the dryer.
The problems I mention, are the most common failures for this symptom. However, please check everything to ensure you rule out all possibilities. If you still need assistance, please let me know. I hope this helps you.
Posted on Nov 11, 2008
4 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
erpaalai
  • 999 Answers
SOURCE: Dryer will shut off after load. Then you can hear
Centrifugal switch on motor is sticking, Eric
Posted on Aug 12, 2009
heatman101
  • 43501 Answers
SOURCE: when i push the start button i can hear and feel
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
I have a Maytag PYE2200AYW electric dryer. we had problems a few weeks ago and discovered that the blower wheel was cracked, so we replaced it (part # 31001317). Then a couple days later it just stops and...
Check the thermal fuse and thermostats again to eliminate them as suspects. Both should be zero ohms at room temperature. If you eyed the entire duct system from lint filter to outside of the house for lint, then these are probably OK.
One thing that will shut down a dryer: a defective door switch. If you turn the timer on with the door shut and can hear or see it progressing (running) then the door switch is OK.
If your door switch is operating marginally, the heat can expand the body of the switch and open the circuit (and shut the dryer off until it cools). Check the switch with an ohmmeter with the dryer disconnected from power.
A loose spade terminal on this switch (or anywhere else) can do this too.
Also, a misaligned door or defective door clasp might do this after heating up.
Keep thinking 'heat expands' and you might find it.
The only other thing left is a defective timer.
Good luck from Detroit, MI.
Jun 11, 2011 | Maytag PYE2200 Dryer
GE dryer model DDE8200GALAD was working fine. After removing a load and trying to dry another, after inserting the load and shutting the door when you turn the timer to start it before pushing the start...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 23, 2011 | GE Dryers
My Whirlpool electric dryer does not shut off when a load is done. The door must remain open in order for the dryer to stop. Other than that, the dryer works perfectly. Is it a switch or the timer or...
Pull the dryer out from the wall and take the vent hose OFF it is in the back, and then try it on auto-dry with no clothes in it and see if it runs through fine if it does not turn off then a new timer should fix it. Good Luck Tim. here is a website that will help click on timer motor, or you can use the virtual repairman:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 23, 2010 | Whirlpool Dryers
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Kenmore 62602 Electric Dryer Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
