Question about Cameras
Pentax Super Program film SLR - fresh batteries,film is properly loaded, film advance lever will not work, feels like it is jammed.
poolseman
  • 206 Answers
SOURCE: Minolta X370 film loading problem.
 First make sure your batteries are OK , camera will not work without two 1.5 v batteries. If your camera still doesnt work this is probably  because the shutter is cocked but you cannot release the shutter and that is why you cannot advance the transport mechanism. The shutter release mechanism needs repairing first. SREMEDY : take bottom cover off ( 4 screws ) and locate 220 mf 6v capacitor ( it is the only one in this part of the camera , cant miss it ). Replace the capacitor while you keep an eye on the polarity ( indicated on the casing of the capacitor ) and you camera should work fine ( dont forget camera needs  two 1.5v  batteries to work ! )
Posted on Oct 11, 2007
cammedic
  • 667 Answers
SOURCE: My rapid wind lever will
If you are handy with tools I can tell you what to try first. This involves removing the bottom cover on the camera (4 screws)
Posted on Feb 15, 2008
  • 619 Answers
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Posted on Feb 19, 2008
cammedic
  • 667 Answers
SOURCE: my camera won't advance the film
If it has not been used in a while, the batteries may be dead and/or the contacts on the cap and in the body may have corrosion build up. Try fresh batteries after you clean the contact points with an eraser. The batteries go in positive up, toward the cap
Posted on Mar 08, 2008
cammedic
  • 667 Answers
SOURCE: Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Posted on Apr 27, 2008
Pentax ME super advance film doesn't get caught
This is a known fault with this retro model, I'm afraid - over time, the plastic gears get worn, and eventually fail. Solutions are mentioned on the Pentax Forums.
Aug 19, 2017 | Pentax ME Super 35mm SLR Camera
Pentax ME Super
Does the film advance lever lock in place when the lever is returned ? if not, the lock spring broke. This is a common weak point in the ME Super. the camera must be partially disassembled to be repaired. get a cost estimate first. there are no new parts for this model Pentax.
Jan 04, 2010 | Pentax ME Super 35mm SLR Camera
I have an old Asahi Pentax, release lever and shutter are stuck.
The Pentax is a easy fix, maybe.. If you feel comfortable removing the bottom cover, then remove the 3 cross point screws. The battery, if installed will be loose. Looking at the bottom section of the camera, locate the tripod socket. On on side is the battery compartment, the other an L shaped lever. Under the L shaped lever is a brass plate with a slot in it. In that slot is another lever that has a spring going through the end eyelet. Move that lever toward the front of the camera until it latches on the L shaped lever above. Then try the release.
The first thing to try on the X700 is fresh batteries. Clean the battery cap and contacts with a pencil eraser.
Jan 04, 2010 | Pentax K1000 35mm SLR Camera
Pentax me super camera, not working wind on lever
The clip spring broke jambing the advance gear. by forcing, the tab on the advance shaft broke.
take or send your camera to a camera repair shop for an estimate cost to repair.
there are no new parts for this model so the repairs could be expensive.
there should be no cost for an estimate.
Dec 10, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME wider II problem
It should stop advancing the film when the camera counter is on #1 exposure with or without film.
Dec 08, 2009 | Pentax ME Super 35mm SLR Camera
Film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
Mar 31, 2009 | Pentax ME Super 35mm SLR Camera
Loading film in my vintage camera..help!
The "magic needles" while making the camera easy to load are about as intuitive as a dead skunk, I had a similar confusion when I got an ME Super. Put the film can in the left side of the camera back (the side with the little thing sticking out is the bottom, it looks upside down this way, but that is correct). Next push the film winder down, this will semi-lock the can into place. Now pull the film-lead across the camera and push it down between some of the white "magic needles on the opposite spool(push it in a bit so that it will stay). Next advance the lever; release the shutter. If the spool starts to turn you are doing it right. Now close the door and continue advancing and clicking until the little frame number window on top reads 1.
May 19, 2008 | Pentax ME Super 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Film advance lever
Your camera is cocked but since the shutter is not working you cannot release it and hence your film advance mechanism does not work. ME-super will work without batteries in full manual mode so set your shutter to B and try to release it. If the shutter will not release in B mode then the shutter/mirror box will need servicing : rubber components in the mirror box mechanism have perished and need replacing. After that your camera will be fine for another couple of years.
Sep 18, 2007 | Pentax ME Super 35mm SLR Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
