Cutis Vcr/dvd recoredr "pop" in audio. Flash across tv screen. Rugh Hum on playback for 2 to 5 seconds
  • murkydee Nov 10, 2008
    I know the problem is not as suggested by tech. But I wonder if the problem could be a filter capacitor in power supply. There is loud "buzz" in audio for about 4 second on playback. Also "Crack" in audio followed by a a flash on screen. Mickey Deems
    Do not accept suggestion frpm Tech. But thanks . Have posted it again, with more clarity. Thanks Mickey Deems
  • 10,594 Answers
Was there smoke, smell or pop sound in your dvd recorder?If yes, its main capacitor is busted / leaky and this can be cause of all above mentioned problems in player.
You need to open player cover and inspect power supply board, there you will see big capacitor. check it has some liquid around or is it bulged.
Thank you.
Posted on Nov 10, 2008
    President:
  • 624 Answers
The "pop" in the audio could be a muting transistor that is not working. When a unit powers on or changes functions it should activate the muting transistors so you will not hear the "pop" noise. If the problem is just one channel, then you need to only check that channels muting transistors, if it is both channels you need to check the muting circuit all the way to the micro, it may even be that the micro is not signaling the muting transistors to turn on at all.
The hum could be a filter cap in the power supply, but may also be bad solder connections most likely in the power supply. They all should be checked.
I do not have the schematic for this unit, plus you never gave a model number so there is no way to look for one. Without the schematic it is very difficult at best, to be able to troubleshoot this type of unit.
Let me know if you would like to get more help from me by addressing your next post to me directly, otherwise it will be unclear who you are wanting to communicate with.
Dave
tech48
    Sergeant:
    Champion:
  • 435 Answers
I am sorry. But I did not understand your question.
I think the text has been mis-formatted...
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug unit from AC mains and remove all cables from unit. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the unit and see if it works..
Good luck..
    Brigadier General:
  • 6,966 Answers
Initially, it would seem that this is a known issue with this model. Often humming sound is introduced from the AC power. In some instances it could be traced to the speaker wires running in parallel with the AC cord or in some instances near the wall outlet. It may also be worth your while to check any and all other cables and connectors attached to the system. In some extreme cases, humming sound enters the system from the very own power supply of the unit and/or for AC plugs that are not polarized. Some have found temporary workaround by using a common polarized filtered power strip. If it is still under warranty, might it be to your advantage to consult your dealer or the manufacturer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
Red error message pops up while watching tv
Sounds like you OTR is on OTR on time record go into your menu of your TV and turn off the OTR feature you should be all set.
Thanks I hope this was Very Helpful for you!
Dec 10, 2009 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Adding vcr & rec to a '93
Please hook up VCR with TV through RF cable and check picture of VCR playback in TV.
Now you can hook DVD player video-audio out in VCR input and can have dvd playback picture in TV via VCR modulator.
If you want to listen sound via receiver then hook audio red-white cable between VCR audio out and receiver audio in terminals.
Let me know exact model numbers of units to help you out more.
Thank you.
Jan 13, 2009 | Televison & Video
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
3-4 switch
1. Set tv to channel 4
2. insert a pre-recorded tape into vcr.
3.press play once to start playback.
4. after a few seconds press play on the vcr for 3 sec you will see a playback picture.
when a picture doesn't appear on the tv screen repeat step 4.
5. press stop to stop playback.
Mar 16, 2008 | Sanyo VWM-950 VHS VCR
Speaker hum on playback with tape or dvd
Any cable? Hum is generally a bad ground. If you use cables and speakers that have no hum elsewhere, and more than one set has hum on this machine, then the unit has a grounding problem, and requires repair on an 'open up the unit' basis.
Jan 11, 2008 | RCA DRC6300N DVD Player/VCR
Vhs playback problem
either extremely dirty heads or there is a tv/vcr button that needs to be toggled. Most have auto tracking, old ones have a knob or 2 buttons under a panel somewhere for tracking.
Dec 02, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Setting up the chanel on the VCR
(FROM MANUAL)
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Sep 02, 2007 | Philips MWD2206 DVD Player/VCR
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
