Question about Kenmore 22422 Top Load Washer
Kenmore Washer makes noise at start of the Spin Cycle
Normal 0 I have a KENMORE automatic washer – Model Number: 110.92291100. It is a 15 year old machine. It has been fixed twice for the same problem – replacement of motor coupling assembly. The first time, we had an applicance repairman fix it. The 2nd time about two years ago (2006), I replaced the motor coupling assembly.
Now, I have a problem with the Washer.
  • At the start of the SPIN Cycle, the washer makes a loud noise. But sevreral seconds (less than 10 seconds), when the tub is spinning faster, the noise goes away, and the tub spins fine.
  • At the end of the SPIN Cycle, when the tub is slowing down, the washer makes the same type of noise until the tub stops.
  • The noise sounds metallic in nature.
Here is the troubleshooting results that I have found and done:
  • I disassembled the washer, and checked the motor coupling assembly. Both the rubber disk and the 2 plastic disks look good. Very little wear and tear. I checked this area first, because in year 2006, I had to replace this assembly.
    • Under the washer, there was some “black” dust, which made me suspect that the motor coupling assembly in the first place.
  • While I had access to the suspension plate, I replaced all 3 suspension pads and all 3 plate pads.
  • All 3 suspension springs and the counterweight spring are in good condition.
  • I reassemble the washer, and tested it with and without a laundry load, and the same problem (making noise at the start of the spin cycle) still occurred.
  • The washing machine works fine (except for the SPIN Cycle issue). .
After troubleshooting.
  • After researching the Internet for Troubleshooting tips, I found some problem cases that suggest that the problem may be with either the Gearcase or the Brake and drive (spin) tube assemblies.
  • After reviewing the washing diagrams from my DIY manual and from a website, I felt that I can remove and replace both parts, if needed. However, the cost of either part is 1/3 the cost of new washing machine, so I wanted to make sure that I could reliably find the root cause(s).
  • I continued to research more articles on the Internet, I found a test case that suggested that “Basket Drive Block” may be problem.
    • Therefore, last night, I tried an experiment as suggested on the web site. I left the lid open, and bypass the safety spin switch with a screwdriver, and started the SPIN CYCLE (with no laundry load or no water in the tub).
    • The noise came up at the start of the spin cycle and then disappeared when the tub basket was at full spin.
    • I, then, pushed down on the agitator cap while the tub was fully spinning, and the same NOISE came back. When I took my hand off the agitator, the noise went away.
  • I remove the agitator to see if I could see anything unusual, but there was none.
  • I am hoping that the problem is with the Basket Drive block, because of the small cost to replace it.
Now, based on what I have written, can you advise me what needs to be done. I know the steps to remove the tub to remove and replace any of the above items. How can I test the gearcase or the spin tube assemblies, when I remove it? Also, is there a repair kit for the gearcase assembly?
  • 63 Answers
Its your basket drive or sometimes called brake spin tube also comes with new clutch, ,transmissions wouldn't make that noise in only beginning of spin. your on your way to being a repair tech good job
Posted on Nov 12, 2008
Kenmore front loading washer drum is loose and makes loud noise when spinning?
sounds like support springs for the drum have become detached or broken. Do not use, suggest new machine as old ones not worth the investment.
Oct 01, 2012 | Kenmore Washing Machines
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
Tub support broke
POST THE MODEL NUMBER PLEASE
Apr 16, 2009 | Kenmore 22422 Top Load Washer
Noise from spin dial...won't spin
Remove the cabinet.
Remove the motor.
Replace the direct drive coupling.
Check the pump for any blockage.
Mar 10, 2009 | Kenmore 22422 Top Load Washer
Washer making noise during the spin cycle
Hi!!! it looks like your motor coupler is failing..Good luck..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 22422 Top Load Washer Logo
832 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
