Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Pulling oil through carb breather
89 fxstc pulling oil and making a mess. About a qt over 2000 mi. Ive heard softails have scavaging issues...why and what do I do to resolve the problem?
    Problem Solver:
  • 6 Answers
By "pulling oil through the carb breather" I assume you mean air breather? The solution to that is to buy an aftermarket "horseshoe" breather. Check Drag Specialties, V Twin Products, etc.
Posted on Nov 23, 2008
What weight synthetic oil for98 fxstc
Hi Anonymous, 20 w 50 Harley Davidson" Syn 3 " you can use it in the engine, transmission, and primary. Good luck
Apr 07, 2014 | 2000 Harley Davidson FXST Softail Standard
2 lines running from the cylinder head into air intake is spitting fluids
Running into the AIR INTAKE, or the AIR FILTER/CARB MOUTH?
If the latter, it's the lines for the crankcase ventilation breather, and quite common for it to carry a little oil mist.
Apr 02, 2014 | 2000 Harley Davidson FLSTC Heritage...
How do I change the oil on a fxstc 2008
Hi Anonymous, for more information on your question please visit the websites below and good luck:
How To Change Engine Oil Filter Without The Mess Harley Davidson Softail
Mar 08, 2012 | 2008 Harley Davidson FXSTC Softail Custom
Where does the oil go from tank when bike sits a long time?
This is what we call "oil sumping" around here. On the soft tail line or any other line of Harley where the oil tank is higher than the oil pump, the oil will seep past the check ball in the oil pump and leak into the crankcase of the engine. When the engine is started up, it will "puke" the oil out. Now, up until the introduction of the Evo engine, the engine would puke on the ground under the bike out the breather tube. Now with the Evo engine and the EPA's regulation that crankcase ventilation fumes have to be fed back through the intake, it pukes into the breather. An even bigger mess. So, what we do whenever we think we've got this situation is put a pan under the shovelhead and panhead bikes, On the Evos and Twin Cams, we take the air breater cover and the air filter out before the fire the engine. It's a mess either way you look at it. I don't think the Twin Cams are as bad as the Evo engines due to the different type of oil pump.
Jul 15, 2010 | 2000 Harley Davidson FLSTS Heritage...
2000 FLSTC Heritage Softail Classic: 2001 heritage is blowing oil through breather.why?...
All Harleys after the year 1992 will have some engine oil carry over visible in the air cleaner though there is a diffrence between excessive and normal although if you get on your bike and travel down the highway at a constant 80+ MPH you will find that you get more carry over to the air cleaner then you would normally riding at lower speeds and this is simply cause you are running the engine harder and therefore you will see more carry over at the air cleaner. Now to be sure, make sure your bike is sitting on level pavement and in the case of a Softtail model it should also be upright and level pull the dipstick from the oil tank and wipe it clean, reinsert fully into the oil tank and remove it again and look to see if your oil level is roughly halfway between the check marks on the dipstick. If so then yes your oil level is good. I would now remove the air cleaner cover and wash any excess oil out of it and if your running a stock air filter and you have had a oil carry over issue for awhile now, then replace the air filter, reinstall the air cleaner cover and go ride the bike for around 50 miles and by ride the bike I mean go ride it like in town and on the highway without being abusive to it or excessive speeds(70 mph). Then remove your air cleaner cover again after your test ride and look to see if you have any oil carry over in the air cleaner. if so let me know and we can go into further detail.
May 18, 2010 | 2000 Harley Davidson FLSTC Heritage...
Crankcase breather
If the bike sits for a while, and then you run it and shut it off, it will drip.. run it more often.
Apr 26, 2010 | 2000 Harley Davidson FLSTC Heritage...
Lands Phones Logo
188 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
