Question about DXG Technology DXG-321 Digital Camera
Lock function on movie function prohibits me from deleting the movie. How do I unlock the lock from the various images?
Lock function on movie viewing prohibits me from deleting the movie. How do I unlock the lock from the various images? It doesn't say in the manual. I don't know how it was engaged.
0 characters
1 Points
The memory card is locked! I don't know how this happened but I want to delete the photos. How do I unlock the card and delete all the photos
Depending on the card, there may be a little slide lock on the side that you can move with your thumb to lock and unlock.
Aug 23, 2011 | Digital Cameras
How do i turn off "File Protect" and be able to delete again. It won't let me delete pictures and there is a little animated figure on the print that says digital camera out to the side with...
You have accidentally selected lock option.You need to select unlock option for the same. Press the menu button and then press right/left button to select the protect menu. Then you need to select unlock and that would turn off file protect.
Kindly accept the solution so that i could get the credit for my time.
Thanks and Regards
Jul 11, 2011 | Vivitar Digital Cameras
I have a Kodak Easy Share C182 . I want to delete some pictures and it tells me to remove protection to delete, and it also tells me image is protected please tellmje stepby step how to clear this...
The most common cause for telling you that the card is locked is having the tiny slide switch on the side of the card in the wrong position.
- see photo below:
Set the lock slider to locked or
  • The down position will enable write-protection, locking the card.
  • The up position will unlock the card, enabling you to save and erase data on the card
kodak-easy-idhgrcvb3gwnj1x0htsxmiux-2-2.jpgthe tiny slider is labeled with "Lock"
SD memory card lock Nikon Knowledgebase
Dec 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
I have a A1250 ge camera. on the sreen reads Write Protect. How do i remove this
Take out the memory card. On one side of the card you'll find a tiny slider with probably 2 small symbols (an open and a closed pad lock). Move the slider to the 'open pad lock' position to unlock the card. It's a safety thing to avoid accidental deletion of your images, but it also locks the card so you can't record onto it either. Anyway, unlocking the card should solve your problem.
Jul 23, 2010 | General Electric A1250 Digital Camera
Cannot turn off picture lock
Connect your camera to PC with Windows XP or Vista via USB, open MyComputer and there should be a camera, which appear as new disk, open it and delete any image you need!
Feb 15, 2009 | Olympus Mju 725 SW Digital Camera
Lock on a picture
Protected pictures cannot be erased using [ERASE],
[SEL. IMAGE] or [ALL ERASE], but they are all erased by
• Go to Playback mode in the camera. Select the picture to be unlocked with the left or right arrow buttons, and to remove the protection select ON with the up or down arrow button.
Dec 18, 2008 | Olympus FE-220 Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Card locked on my optio w10
Check your manual for the image protect function. or simply reformat in camera.
Jun 14, 2007 | Pentax Optio W10 Digital Camera
DXG Technology DXG-321 Digital Camera Logo
18 people viewed this question
Top DXG Technology Digital Cameras Experts
Derick Williams
Level 1 Expert
Are you a DXG Technology Digital Camera Expert? Answer questions, earn points and help others
