Koss dvd player kd 305
I accidently hit the pal ntsc? button and now my dvd player does not work...black screen with not supported mode message
  • muff_a_medic Nov 11, 2008
    There is no disk in the tray and I cannot hit the pal button because I cannot get the menu to show or anything else for that matter.
    Still does not work.
    Scholar:
  • 124 Answers
Make sure you dont have a disk in the tray. Hit the Pal.ntsv button 2-3 times. You will get the picture back. If not, then you also hit the p.scan button. Hit that button 2-3 times till you get the picture back.
Posted on Nov 10, 2008
  • Mike H. Nov 11, 2008
    Make sure you DO NOT have a disk in the tray. Hit the p.scan button. Hit that button 2-3 times till you get the picture back. Each time you press the p.scan button, give it a second before pressing it again.
    Try this,
    Go in the back of the DVD player, and switch the connection.
    If you are using the yello video cable, remove it and insert it in the component connection. Insert it in the "blue" connection. You should get a picture. Now just go into the menu and undo the setting.
How to Change NTSC/Pal ?
press the button again
or try taking out the
DVD
Jan 10, 2010 | Televison & Video
How to make PAL region code 2 dvd's work on a regular tv
The tv in U.S. and Canada can't set in the play pal mode.Only in NTSC mode.
Aug 13, 2009 | GPX D1816 DVD Player
The display screen is rolling and is in black and white.
Hi
You switched to PAL mode from NTSC or vice versa. Most DVDs will only output PAL or NTSC, not both. So even if the disc is region ffree, the fact that it's encoded in PAL (50hz) makes it appear like you describe - no vertical hold / black and white.
Some set top players [Apex, Phillips] will convert PAL to NTSC on the fly or vice versa.
Remember, PAL/NTSC is not the same as Region.
Here's some detailed info:
http://www.michaeldvd.com.au/Articles/PALvsNTSC/PALvsNTSC.asp
http://www.sjbproductions.com/web_pages/tip_video/ntsc_pal.htm
http://www.dvdcity.com/codefree/codefree-ntsc-info.html
You can convert the DVD to NTSC, and strip the region code by following http://www.videohelp.com/guides/how-to-convert-interlaced-pal-dvd-to-ntsc-dvd-id1107#1107
-or-
http://forum.videohelp.com/topic221928.html
[This is very time consuming.]
You
What DVD
Most players are either NTSC or PAL, however increasingly DVD players from the Far East (Apex, Phillips etc)
, which is 50hz instead of 60hz, hence the lack of vertical hold
Mar 23, 2009 | Televison & Video
I,ve touch a function and my dvd plays but it is Black and White and the image rotate, I know that I went into picture ...i believe and set it to something else cannot bring it back to normal function DVD...
yes , i can help,> open dvd tray, your player will go to menu but it will be jumping so look to bottom of screen to tell what function you are in. scroll down till you see "display lets you display picture etc." when you see this at bottom of screen hit enter and and hit bottom arrow you will see pal/ntsc option hit enter again and your picture will return to normal good luck.
Nov 26, 2008 | Koss KS3112 DVD Player
Split Screen Output
check on the remote if got some function of format ntsc or pal or check on the menu of the dvd
Oct 31, 2008 | JVC HR-XVC33U DVD Player/VCR
Switching form PAL to NTSC
did you tried to switch back to factory settings? thanks
Apr 11, 2008 | Bose Lifestyle 38 System
Color
It could be a result of wrong broadcast system matching between the player and the TV set.
Press PAL/NTSC button in STOP mode to switch the broadcast system between PAL and NTSC.
Do you have the manual?
Jan 10, 2008 | GPX D1816 DVD Player
Lost video output
You might have changed you settings for video type, PAL or NTSC or the letter box or 4:3 or 16:9 etc..
any way if your player contains a battery to retain settings unplug your player and remove the battery
if it doesnt have a battery unplug for 24 hrs,
you shold look at your remote for a button labeled P/N or N/P or ntsc/pal or pal/ntsc, or something close to that,
just press the button
if that dont work you can remove the batter and unplug for 24 hrs or if it dont have a battery just unplug for 24 hrs
IF THOSE DONT WROK POST YOUR PLAYER BRAND and MODEL i can advise you further then
Jan 02, 2008 | Koss KS4110 DVD Player
Koss KS5190 Display mode stuck
I'm not ranked and I'm not a Guru, but I can solve this picture rolling when the problem is "the video was accidently changed from NTSC to PAL and you can't see what your doing to get it back". You will need the remote control unit. First, remove the disc from the tray. Now, turn the unit off with the power button. The tray will close by itself. After the display on the front of the unit goes out, turn the unit back on using the remote control. This will let you know the remote control unit is working. When the power comes back on and the display on the front of the DVD player says, "NO DISC", with the remote control and (very important) while pointing the remote at the player, (Remember to point the remote before pressing any buttons) press the "Down Arrow" button 3 times. This will take you to the "Display" box. Now, press the "Right Arrow" button 1 time. This will take you to the "TV Image"box. Now, press the "Down Arrow" 1 time, this will take you to the "PAL/NTSC" box. If you have done everything as I have tried to clearly lead you blindly to your destination. Press the "OK" button 1 time and the picture on the screen will stop rolling and change from black & white to color. You will have now changed your video output from PAL to NTSC. If you press "OK" again, it will start to roll again. If this did not take care of your problem, turn the player off and try it again.
The previous problem solvers were on the right track, but the track was rough and they just about derailed the train. Thanks to them, I had a track to follow. I had no other information, except what I found on "Fixya.com". MR. CD
Feb 03, 2007 | Koss KS5190 System
Sony Mobile DVD MV-7101 Display is Black and White
Try pressing the arrow up on your monitor while it is on the PAL mode. This is what I just tried on my systema and it switched from PAL to NTSC.
Jan 07, 2007 | Sony MV-7101DS Car DVD Player
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Electro Med Services...
