My acer veriton 3900pro when starting up , the fan goes crazy and makes a noise like a vacuum cleaner and won't stop. what can i do
  • Anonymous May 05, 2009
    lan not conect
3 Suggested Answers
natzki
  • 124 Answers
SOURCE: Hi there! I have a problem with my Dell Optiplex
Try to check in the Bios if there's an option to adjust the fan speed of your CPU. If not try speedfan, its a freeware : http://www.almico.com/sfdownload.php
Posted on Oct 12, 2010
  • 8909 Answers
SOURCE: I have Acer Veriton 5800 desktop and often the
Most desktops have fans fitted, especially in the power supply.
The bearings and not that good and become noisy when older. They are replaceable but a replacement power supply is far less effort.
Show the fans a plastic pipe from a vacyym cleaner from time to time, that will make the fans more efficient and reduce the wear and noise.
The hard drive can get noisy also, (if it is I would before it is too late), recommend replacing it.
Hope that helps.
Posted on Dec 09, 2010
Acer Veriton m264 wont start
check all fans are working and that its not over heating
May 26, 2014 | Acer Veriton Computers & Internet
Acer Veriton M498g - ui3540c won't start
Need more info, Give as much detail as you can. What happens when you push the on/off button? Fan spin? LED's Blink? Any thing on the screen? Sound? Does the computer try to start and a second later shut down? Check the power cord, check the AC outlet? Is it on a UPS? Try AC outlet? Can you get to BIOS or Boot Menu? ETC.
Feb 14, 2013 | Acer Veriton M498G-UI5650W Desktop PC...
My Acer Veriton X480 turns off after few seconds and won't boot.
Have you cleaned it lately? Is it getting sufficent air flow? A few cans of compressed air and a can of Electronic Contact Cleaner spray. If so, I would suggest the PSU may be bad. Reseat the memory mods, Try to reboot. If it starts, LED's blink, then completely powers off, Test the PSU with a multimeter, replace if necessary. Do you get anything on the monitor? Or does it shut down before? Had you done any hardware or software updates/upgrades?
Jan 10, 2013 | Acer Veriton X480G 320GB PSV9703004 PC...
I have Acer Veriton 5800 desktop and often the noise get louder and faster and then it quieten down. Do you think it a fan?
Hope that helps.
Dec 09, 2010 | Acer Veriton 5800 PC Desktop
Acer veriton M460 will not boot up
The acer veriton m460 has three faulty capacitors. Check and see if you have bulgy capacitors. I have ten of these computers and all have three blown capacitors.
Jul 31, 2009 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
1997 Dodge Grand Caravan heater blower makes clicking noise
take out the blower motor
if the bearing is ok
use a vacuum cleaner to suck out the debris in the piping
Apr 28, 2017 | 1997 Dodge Grand Caravan
Dwin Trans3 Plus will not lite
I had a similar problem and it turned out to just need a good clean. The fans can pull in a lot of dust and eventually this causes intermittant starting problems/noise. I attacked mine with compressed air and a vacuum cleaner and this completely fixed the problem. Try to control where the dust goes you want to avoid just blasting it inside the unit and on the lense, bulb, etc
Dec 31, 2008 | Dwin TransVision 3 Plus Multimedia...
Power supply fan is makeing a lot of noise
1) Unplug the power cord and give the fan a good cleaning
with a soft paint brush and a vacuum cleaner.
i.e. Let the fans spin up by the vacuum and than bring
the brush against it.
2) If this fails, it's time to replace the fan:
a) Upgrade or replace the power supply enclosure with more
power/higher quality.
This is usually a good investment anyway.
b) Replace the fan only as described below:
Open up the computer (remove sides)
Unplug all the power supply harnesses from
the mother board, drives and chassis fans.
Unscrew and remove the complete power supply
enclosure at back of computer (ie top of the tower)
Vacuum it out as much as possible.
Disassemble the power supply enclosure by removing
more screws and removing the metal cover.
Unplug the fan from the circuit board, remove it
and take it to a computer store/ builder.
buy another fan just like it
reverse the process to put your computer back together.
1) A new power supply should cost $65 to $120
depending on power and quality. The bigger the better.
But make sure it fits mechanically into the existing chassis
and that the AT generation matches ***********-board.
2) A new fan should cost $15 to $25. Makes sure it runs on
the same voltage, and that it is physically compatible.
Martin
Apr 24, 2008 | Computers & Internet
Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Mar 26, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Computers & Internet Logo
722 people viewed this question
David Payne
David Payne
