Intrtherm electric furnace fan weak to start turning
    Scholar:
  • 66 Answers
Check to see if the capacitor for the fan motor is good, if good, probably a bad or weak fan motor.
Posted on Nov 11, 2008
My electric coleman furnace will not run.
Depress the interlock switch manually as the furnace is starting up. That should give you your answer. Some furnaces (mine) rely on a friction fit of the cover panel to close the switch. Over time, the friction fit stops fitting.
Feb 25, 2017 | Heating & Cooling
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
We have a Coleman Electric Furnace Serial # AOL6042086, Model # AHP36C3XH21A and the fan runs constantly, will not shut off. We have replaced the thermostat and just replaced the control board. We h
I wish I was a furnace expert but I will give a push in the right direction. When a gas/electric fan runs it has two speeds. When you turn on the FAN ON switch it should run at the slower speed. If it doesn't turn on or turn off again when you turn it back you have a wiring problem or a thermostat problem. Make sure the thermostat is compatible with your unit and wired properly (on both ends). The other time the fan runs is "in session" when heat or cooling is applied to the system. It should run until the system finishes the cycle then a bit more (30 seconds or 1 minute) to blow the treated air completely through the ducts. If it doesn't stop then you may have a bad fan time delay or relay. Check parts for your model and various appliance repair site online.
Nov 25, 2014 | Coleman Mobile Modular Home Electric...
Furnace will not run when hooked up to electricity
Go to your thermostat and access the fan mode. Change the fan mode to Automatic, AU. This will stop the AC fan from blowing when the furnace is turned on. If the fan mode is on Hi or Lo and the furnace is turned on it will turn on the AC blower. Bad design...
Mar 02, 2014 | RVs
INTRTHERM MODEL MGHB -056ABFC-09 FAN KICKING IN OUT EVEV WHEN WARMED UP
The fan speed might be set to fast cooling the fan limit control prematurely. Or the fan limit switch is not calibrated correctly. Or the fan limit switch is bad.
Dec 21, 2013 | Intertherm 56000 Btu Gas Furnace
Auto fan does not start electric furnace
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked.
If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide).
If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports.
If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
Oct 08, 2012 | Coleman Mobile Modular Home Electric...
Urnace fan of some sort runs all the time - set on automatic
If you have it cleaned twice a year they should be able to find this problem. It is one of two thinkgs. There is a limit switch on the fan at the top (inducer) this may be weak and causing the inducer run frequently. The other is there is another limit switch it is a main limit on the fire wall it is also weak and that is why the main blower is running it is trying to cool that limit.
Jan 26, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
