Question about HP Office Equipment & Supplies
My HP Laser jet 3055 has worked fine for a long time but now when I press "scan to" an error message pops up on the printer/scanner "not set up on pc". Nothing has changed and the machine has not been moved?? I have checked all of the connections. It did this about 3 weeks ago and I fixed it but I'm not sure how I did it.
  • Anonymous Jan 28, 2009
    same problem for me
  • rhnkhn32
    rhnkhn32 Jan 04, 2012
    same problem when i do it
  • 345 Answers
Have you plugged in your printer into a different USB port on the computer? If so, return the USB cable to the original USB port it was in before. If not, try another USB port on the pc and have the driver disk handy because it might act like you have never had the printer plugged into the PC before.
Good luck
Posted on Nov 10, 2008
Please give explanation & soulation hp laser jet 3055 scanner error 6 \r\nWhy this problem are create in our printer
Scanner error #6 = DocOriginFind
Per the service manual here are the steps:
1 - Power Cycle the Machine (I'm sure you've done this already)
2 - Replace the Scanner Assembly (After replacing this if the message still appears then.. )
3 - Replace the Formatter and Line Interface Unit (LIU)
Oct 20, 2010 | HP LaserJet 3055 All-In-One Printer
HP Laser Jet 3055 is showing scanner error 6 and Comm. error 386, 232, & 388
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
1. Turn off the all-in-one
2. Press and hold down the * and enter buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. Allow the all-in-one to return to Ready before using it. storage init. appears, and then release the buttons.
if this does not work contact hp 1800-334-5144.
Jun 14, 2010 | Office Equipment & Supplies
Laser jet 3055 scanner error 6
Generally, Error 6 is a failure of one of the PCA boards and the unit requires service.
Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
Hp laserjet 3055 has code 52 scanner error and wont print or copy
PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Jan 15, 2010 | HP LaserJet 3055 All-In-One Printer
HP Laser Jet 3055 printer-52 scanner error?
Remove the top cover. The laser / unit is a black box.
to purchase one.
Jan 15, 2010 | Office Equipment & Supplies
I am having prob with ma HP laser Jet 3055
firstly restart the printer and put the blue wire into the red pocket vice versa it should work
Aug 13, 2009 | HP Office Equipment & Supplies
Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
Printer not working
Contact HP tech support for a replacement bulb (or a quote on one).
Jul 04, 2008 | HP LaserJet 3055 All-In-One Printer
Document loaded showing 3055
Sensor flag would have got stuck, check adf paper presence sensor
Oct 09, 2017 | HP LaserJet 3055 All-In-One Printer
125 people viewed this question
Ben Johnson
