Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Where can i get my saeco vienna machine repaired in Houston TX
  • Jill29 Apr 27, 2009
    My Spedem Divina (made by Saeco) Expresso machine is broken, too. Do you know a repair shop in Houston to fix it?
    jill_mercado@yahoo.com
  • 3 Answers
Purple Turtle Coffee
211 W, Main St
La Porte, TX 77571
281 470 6555
I just picked up my repaired Saeco expresso machine. The people that work here are very professional and spent a lot of time with me showing me how to properly clean my machine. It was about a 30 minute drive east from my house near the Galleria but it was WELL worth it. I say that as I sip on some homemade Latte - yummy!
Posted on Apr 29, 2009
    Sergeant:
  • Saeco Expert
  • 223 Answers
You can look at www.Saeco-Usa.com for a service center list.
For a saeco service center in New York contact:
Cerini Coffee Services, Inc.
www.CeriniCoffee.com
Posted on Nov 25, 2008
My Vienna plus espresso machine remains on will not power off unless I unplug it from the outlet.
You will need to have the on-off switch replaced or repaired, so check around and call a number of stores in your area who repair those kinds of machines, tell them your problem, and see if they'll give you an approximate cost to repair/replace the switch. It shouldn't be very much.
Oct 28, 2014 | Saeco Vienna Plus Espresso Machine
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
May 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe
http://cerinicoffee.com/Saeco_User_manuals_free.asp
Apr 26, 2008 | Saeco Vienna Deluxe
Saeco Vienna Deluxe odd burning smell
gears are probably broke. Happens when to much coffee and coffee ground too fine get compacted into the brew drive unit.
Shreds the plastic gears like butter.
Machine has to be sent out for service, gear replacement is long and impossible for anyone untrained. Trained techs it takes at least an hour if not more.
Apr 21, 2008 | Saeco Vienna De Luxe Espresso Machine
www.saeco.ca
1743 Boundary Road
Vancouver, BC
(604) 299-7555
Dec 14, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
401 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
