Question about Alpine MRP-M650 Car Audio Amplifier
Amp staying on but cutting out?
Alright it's getting real old, and expensive! At first I thought it was probably my amp but bought another amp and I am having the same problem! The power to the amp is staying on but My sub just stops hitting,and it cuts in and out, It will work for as long as I'm driving I will park my car, and when I turn it back on every thing will be working just fine and, then a couple minutes later, amp cuts out and won't hit for a couple hours or a couple days.... I have checked the sub multiple times and I don't see it being the sub or the amp... I have never had this problem before, and I had been running the same sub and amp for a year and a half, and never had a problem till now(and now I have tried 4 different amps and still the same thing happens).... so my guesses are it's grounding somewhere, short in some of the wiring, might just need a new battery...Idk could use some help on this one! Thanks
  • Willb2396 Nov 13, 2008
    Thanks for the help, but I had a buddy of mine who owns an audio store look over everything, and It turned out to be nothing but the wiring in the box, It wasn't a problem with the alternator or anything of that nature, just turned out to be something I overlooked, and didn't think to check, which was a screw up on my part! Just goes to show it always turns out to be something simple, which really sucks cause I did strip everything down to make sure nothing was grounding out! And the only reason I did mark as "Thanks for Trying" is because I was pretty sure the alternator wasn't going bad because, the car is pretty much new with only 15000 miles on it, and I am only running around a 600 rms amp.. But thank you very much for the help, I do appreciate it!
It's cool man! We all have those days! once again thanks for the help
Posted on Nov 14, 2008
    Genius:
  • 1,139 Answers
Hello Willb2396,
Actually you answered your own question in your paragraph. I draw your attention to your statement of:
"It will work for as long as I'm driving I will park my car, and when I turn it back on every thing will be working just fine and, then a couple minutes later, amp cuts out and won't hit for a couple hours or a couple days.... I have checked the sub multiple times and I don't see it being the sub or the amp"
You are correct it is neither the Sub nor the Amp. The problem is either your voltage regulator or your alternator. one and or the other is going bad.
Here is some advice check your ground wires, the buy a dual alternator kit, it contains the parts you will need to add an additional alternator to your car. This will provide the power you need.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 10, 2008
  • Henry McKelvey
    Henry McKelvey Nov 13, 2008
    Hello Willb2396
    I have a question, "what do you think the problem is?" Because by your own admission you have tried a number of Amps and Subs, so we know that it's not the subs and amps. You believe its a grounding issue, OK in that case recheck your ground using an ohmmeter and making sure you have no ground loops. Now after taking care of that there is only one system that applies here and that is the vehicle's power plant (Battery, Alternator, and voltage regulator which is sometimes part of the Alternator). Correct me if I am wrong, you have eliminated the Amps and the Subs as problems, you have checked the grounding to make sure it is secure and ample? Now in that case what is so out of line with my advice that it warrants a ":Thanks for Trying" since it is the only system left?
    I understand that this is a lot of work and you may not feel like adding the extra alternator and voltage regulator, but, that is what you need because when you stop driving the car goes to idle, and the output of the alternator at this point is not enough to support the power needs of your sound system. So in order to take care of that, guys who do this for a living, such as a few people I know including myself do is add an extra alternator and beef up the grounding plane. What I did was to employ what is called a ground window, which I run all of my grounds to and then run a single heavy gauge ground cable to the automobile ground.
    The problem you are having is a power plant issue which may be exacerbated by the lack of a good ground plane.
    In any event, I wish you well in finding the solution to your problem.
    Thank you,
    Shuttle83
  • Henry McKelvey
    Hello Willb2396,
    First I would like to apologize for my attitude, I had a bad day, but that was no excuse to vent on you, I was working on a system and found that someone had completely redone what it took me two weeks to do and I was in one of those moods that get folks into trouble. So as stated before I apologize for my venting on you.
    I am glad to hear that it turned out to be as simple as a wiring issue. Again I ask that you accept my humble apology for without warrent venting at you.
    Thank you,
    Shuttle83
My 2003 Mercury Mountaineer has an electrical problem. It started about a year ago with the key fob not working, I have bought 3 and all won't work even after re-programing. now tonight I went to
Could be a windshile leak down the A-Pillar & water
gets into the delayed accy relay for the GEM Module
(Body Computer as ford called it for a few years) & you
get what you have now
Try Goolge as I did a few weeks ago for a relative
He had the same issue with the blower being on &
killing the battery
No real fix I found for the windshield leak
Seem a robot didn't put the rubber sealant
on correctly at the factory fo about 5 years
on several fords.
If it isn't water related then the GEM Module
controls all those body features
If you get a used one & match up the numbers,
you supposedly can avoid buying a reman gem
& the expense of having to reflash it to your factory
built combination
Jan 27, 2013 | 2003 Mercury Mountaineer
Garmin nuvi 1300 Query
Usually they come preloaded with some maps and you purchase additional ones. Check the manual that came with it or the box and that should tell you which ones it has. Generally speaking a basic unit bought in the UK will come with UK & Ireland preloaded, more expensive unit may have UK, Ireland & Europe and the most expensive may have all three plus USA. It's unlikely you will have 'lost' your USA map. The unit should have a 'drop down' menu which allows you to choose which map to load. Hope this helps!
Jul 26, 2010 | Garmin nuvi 1300 Car GPS Receiver
When i cut the volume up on my radio or turn the bass up the amp cuts off and on
check all wires .... make sure your speaker wires arent in the wrong order or shorting ...
did this just start of was it always going on ... if it just started its probly a short in the wires
Feb 10, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Beko SCG 7521 gas cooker flame won't stay lit in oven.Once you light the flame in the oven & hold in the oven button for the recommended 10 secs it cuts it's self off when you release the oven...
bloody hell that is so scarey i have the same problem and its round about the same time yours went funny if you have a solution can you let me know as im looking for the answer myself klass-a@hotmail.co.uk
Oct 08, 2009 | Ovens
Just bought a 92 maxima se and it slightly clunks from 1st to 2nd it's automatic any ideas
I'd start with a fluid & filter change just in case that's all that's needed. Who knows when & if that has ever been done, and it's real good, least expensive way to start.
Aug 08, 2009 | 1992 Nissan Maxima
Amplifier protect circut is on and wont shut off
ALL AMPS HAVE PROTECTION CURCUITS, U NEED 2 CHECK ALL YOUR WIRES THAT HAVE ANY POWER RUNNING THREW THEM, U PROBLY HAVE A PINCH IN A WIRE CHECK ALL UR CONNECTIONS.
Mar 20, 2009 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Amp or Stereo Cutting out...
I agree with what you think it might be. I really think its the deck that is bad and you should be able to take it back for a new one. Have you tried unplugging the RCA cables to the amp to see if that stops it? That would tell you if the amp is backfeeding or doing something weird.
Mar 02, 2009 | Dual Car Audio & Video
Cutting out intermittent problem
If the voltage is dropping to 8v, it sounds like there is a problem with either the B+ line or the ground connection. You should also check the voltage across the battery terminals to see if the voltage is dropping at the source.
The amp may be going into protect mode. Disconnect all speaker wires from the amplifier's terminals. Also disconnect the RCA cables from the amp. Does it still go into protect?
Insert a 20 amp fuse in the B+ line and try to power it up. If the fuse blows with no speakers connected to it, the amp probably has a blown channel.
Dec 05, 2007 | JBL GTO75.4 Car Audio Amplifier
Alpine MRP-M650 Car Audio Amplifier Logo
211 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
