The trigger/valve does not control the flow of fluuid from the tank to the brushes,. The valve is always open regardless of the trigger position. It appears(visually) that the rigger operates the linkage to the valve assembly but the valve fails to close. I assume the valve is designed to be normally closed but it apparently is always open and the mechanism fails to close when the trigger is released.
I replaced the water control solenoid and it cured the problem.
Posted on Jan 06, 2008
It maybe that a water line has come off, where does it appear to be running out? Bottom of the tank, or down below, Bottom of the tank may have a bad seal or has a crack under the the seal, on the platform where the tank sits on has 2 or 3 tubes that hook up to it, check to make wure they are on, or a line could have come loose at the bottom, there you would have to take the top cover off.
Oct 19, 2014 | Hoover F7452-900 SteamVac Upright Vacuum
Oct 04, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
Apr 14, 2010 | Hoover SteamVac V2 6-Brush Widepath...
Nov 23, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Nov 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Jun 10, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
May 15, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Apr 22, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Feb 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
179 people viewed this question
I have the same water flow control problem. The unit has only been used 3 times.
