Question about Sony KP-53S70 53" Rear Projection Television
Can't find the cooling fan
I got a tip on here about blowing out or cleaning the cooling fan, but can't seem to find it. Am I missing it, or does this model not have one? P.S. it has no picture, and LED blinks 4 times then stops and blinks 4 times.
  • vam113 Nov 12, 2008
    You the man thanks so much for the good info.The bad info came from this site i think it was under no power tv blinks 4 times for kp53s70.Again thank you Scott
  • 320 Answers
Unfortunately, you apparently got information from someone who has not had training on your set. A 4 flash on your set indicates a vertical stop, meaning that the vertical drive circuit has shutdown. Possible causes are a bad vertical drive or vertical output IC. I can't be more specific because I would have to check a couple of things, starting with the 135 volt power supply line to see if it is coming up. You can stop looking for a cooling fan because this set does not have one.
Posted on Nov 10, 2008
  • Any Guy
    Any Guy Nov 10, 2008
    If you could let me know where you got the bad information I would appreciate it.
Blowing off fan I knocked of 2 wires to power button how do i hock them back up to mother board.
pinpoint of liquid solder after area and tips of wires are cleaned.best to solder wires first called tinning to put solder on tips of wires. direct hook wires to board. clean under fan and cooling fins first.
build a different plug use lots of light a steady hand and silver solder with flux core with a fine clean tip of soldering iron.gotta be quick and dont let solder get on other areas or short circuit anything else.
Oct 26, 2013 | Gateway Computers & Internet
We have model #57915.54. The fan and compressor run, but is blowing hot air. Is there freon for the unit? If so, I heard that there was a kit you could purchase to do it.
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure. If leak call repairman to rectify it.
Jan 11, 2011 | Heating & Cooling
My Frig does not work, Yesterday the frig started to get warm until it is totally warm, I cleaned the coils, compressor runs, fan blows, fan on the coils blows. It seems like the compressor cylces...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Electrolux Refrigerators
Not getting cold enough to freeze, How to check Freon
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jun 05, 2010 | Kenmore 53082 / 53084 Side by Side...
Engine running hot,near boiling and electric fans are not running
Here are the possibilities: 1.radiator cooling fan switch (one of 2 types are listed for your yr. and model-one is mounted inside the thermostat housing, or engine mounted, not sure which you have. 2. Radiator cooling fan relay-located under the hood in fuse/relay box. 3. bad cooling fan motor. Don't run the car until you fix this, as you risk blowing a head gasket or trashing the engine.
Dec 07, 2009 | 1992 Honda Civic
It's not blowing enough cool air out. It sometimes accumulates ice behind the filter.
seems like its clogged up and needs a good cleaning. fan could be all dusty, etc
Jul 09, 2009 | Heating & Cooling
How to repair vgn-sz430n cooling fan
Did you try blowing it out with compressed air 1st?.
Sometimes it's just dirty and plugged up with dust.
May 26, 2009 | Sony VAIO VGN-SZ430N/B Notebook
Laptop overheats way too fast...
What is the model number of your machine? Some have design flaws that make them run hot. Also dust is a great insulator. I would take the machine into a repair shop or get a can of compressed air and blow out any fan areas. A laptop cooling pad can be a good idea as well especially if you notice that the machine overheats while sitting on a desk. The noise of the fan is probalay due to the dust coating the heatsync. The fan has to run much faster to move more air to cool the system. Blowing out or having the heatsync cleaned is a good idea here!
Dec 06, 2007 | Computers & Internet
Sony KP-53S70 53" Rear Projection Television Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
