Question about Enlight 3 Bays (DM001203) Serial ATA Storage Cabinet
No activity leds blink
The activity leds not functioning
0 characters
1 Points
My external hard disc moder no : TS80GSJ25S shows there is no disc in your drive
If you have used this drive before then the drive is malfunctioning and my need to be formatted. If not, then the disk could need initializing and then formatting. You can check the status of the disk using the windows disk management utility. The directions to use this utility are shown below, If the disk does not appear in the manage disks section, check the connection to the computer, and try to power cycle the drive by unplugging it, waiting for about 20 seconds and then plugging it back in. This may renew the connection and restart the drive.
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments. Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives
Jan 09, 2011 | Transcend StoreJet USB 2.0 External Drive...
Where do I buy a spare power adapter pa-225
For those who run across this situation, don't add to the land fill if you can fix it. The majority of the problems with the PA-225 and 226's, is the DC plug connector that connects to the MX-1. That plug's connections are 4 pins and one thru-hole terminal that's meant for the center wire, ground line connected to the plugs metal jacket, which is the ground for both 5 and 12 volt lines. The problem is that during assembly, they miss getting the wire through the eyelet of the ground terminal and solder it anyway, which usually creates an intermittent or permanent disconnection later. Although this can happen for the pins, the main culprit is this ground connection. When this becomes disconnected, the LED will Blink indicating a problem. Normally the LED is a solid orange. The plug's molding can be cut (spit in half) and slid back to expose the plugs ground terminal. The inside molding can be cut/chipped away in if need be to expose the ground line. You might need a really good mag lens to show the fault. I took some pictures and created a pdf on what I found but haven't posted any where. If all else fails, you can order one from Antec. However, beware that the connector used on the replacements will most likely not be the same as the originals. So, if your supply is really DEAD, keep it for the 4 pin male connector, and check out this Antec Online Store for their replacement. Also be aware that I've discovered that the original supplies, two of the pins are used as one 12v supply, and the other two pins are the 5 volt supply with the plugs metal jacket as the ground for both. The original supply's labeling is incorrectly pictures as each pin pair being both positive and negative, with the metal jacket not connected. Make sure that this your next supply does not ground to any of these pins, only to the jacket. The motherboard inside the MX1 connects each pin pair together for a positive terminal only, therefore, if you get a supply incorrectly matching, you can toast a new supply. If you look at the male connector from the original supply with the plastic key "top". The left pin pair is 12VDC, and the right pair is 5VDC with the metal jacket as ground for both. Good luck.
Sep 23, 2009 | Hard Drive Accessories
Hard Drive won't spin
I had this problem and I found out that plug & play wasn't enabled in the bios.
Dec 30, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
KINGSTON pen drive is not responding
hi i am jimmy patel
i purchase a kingston pendrive but it is showing mall function and it is not working so provide me the solution
Jan 20, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Led won't light
Just bring the sample when buying led, and you cannot reverse the connection of led it has a polarity. If you reverse the connection it wont light.
Jan 02, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
NSP 352U
Fry's electronics has replacement LED's. If you cannot find it please let me know and I will see if I can get one to you.
Jun 11, 2007 | Nspire 1 Bay 352U (NSP352U) USB 2.0...
Installation of external hard drive
The drive should not be set as "master" if your not booting from it and only using it for storage. Master means the bootable disk that holds the operating system. You should change the setting to slave or cable select.You can format it, but chances are it is already formatted and ready to store. Good Luck, Tim
Feb 12, 2007 | StorTecc PM-350E2-EES Portable Media...
Red blinking light on my acs-100
I've actually no idea but instead of troubleshooting it you might want to try to reconnect it by following this guide: [url=]ACS 100 User Guide[/url].
Sep 19, 2005 | Adaptec 1 Bay ACS-100 (2177400) USB 2.0...
Enlight 3 Bays (DM001203) Serial ATA Storage Cabinet Logo
22 people viewed this question
Top Enlight Hard Drive Accessories Experts
Are you an Enlight Hard Drive Accessory Expert? Answer questions, earn points and help others
