Samsung HDTV LN-T5271F
Picture is cut off at top and bottom
  • 5 more comments
  • plerway Nov 10, 2008
    Have had TV since 1/08 and problem started about 2 weeks ago, late 10/08.
    "hard" re-set did not work. Any more suggestions?
    Convergence IC's???
    what is that? Greek? I need help not doublespeak.
    picture is cut off at top and bottom. Have tried power disconnect; no good.
    what else can I do?
    no black bars; no zoom mode; have changed from 16:9 to Just Set, or whatever, nothing helps; in fact, the zoom modes are not in bold and cannot be used; when watching football, none of the info bars at top or bottom appear; on news channels, the scrawl at the bottom is completely invisible.
    "Normal mode" setting? I don't have such a mode, unless you mean 16:9.
    the picture is cut off at the top and bottom
  • 153 Answers
Definately it is the main board problem, check the electrolyic capacitors on the main board for any buldgy caps and replace.
Posted on Nov 10, 2008
    Sergeant:
    Champion:
  • 331 Answers
Does the picture remain
so even when playing DVD's ????
or is it only when viewing the channels?
  • 899 Answers
This is a component problem ,and no combination of buttons or unplugging the unit will fix the problem
  • 1 more comment
  • jason Nov 10, 2008
    if it looks like this ( , bowed on top and bowed on bottom then it is a component problem
    sorry , these are straight lines across the top and bottom , which would be a video board
    this is a component board that is causing all your channels to be cut off , it will need to be replaced to correct the problem
    did this happen while you were watching? or did you just notice it when you turned it on?
    President:
  • 1,257 Answers
Download the user manual for SAMSUNG LN-T5271F and go with Resetting the Picture Settings to the Factory Defaults
Here is the link
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/LN-T5271F-_F
The problem here is that the top and bottom of the image are cut off
The one exception is if you are watching a standard definition show that is formatted for wide screen. “Law and Order” is a perfect example. Watching this on a wide screen shows black bars above, below, and beside the image. If you use the zoom mode on this programming, the original image will expand to fill the screen with no distortion and no cropping of the image. Aside from this one exception, I recommend that you leave your HDTV set to the Normal Mode setting.
    President:
  • 2,712 Answers
You have a bad vertical output IC and or a bad capacitor in the vertical drive or output circuit. You will need the services of a professional technician to repair this.
  • Swilin Sampson
    Swilin Sampson Nov 10, 2008
    Does this happen only on digital channels, or all channels?
  • Swilin Sampson
    You could also try altering the view settings via the remote. Try the various settings and see if this helps. you could also try the ZOOM function if available. It all depends on how the original signal is sent from the cable station.
    Should the view settings not help, then it is most likely the IC or capacitor as mentioned earlier.
  • 19,396 Answers
It is a convergence problem.
Probably one of the convergence ICs had blown and must be replaced.
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck....
  • Anand Kumar
    Anand Kumar Nov 10, 2008
    Try to play a dvd and check if the screen as the same result ...
Blurry picture ON LEFT THIRD OF SCREEN
Do you have a picture? Sounds like a failing LCD panel
May 08, 2013 | Samsung LN-T5271F 52 in. LCD Television
Samsung LNT-5721 picture background is green
READ THE OPERATING MANUAL CARE FULLY IN SETTINGS YOU WILL FIND HOW TO CHANGE THE BACK GROUND COLOR. OR LOG ON TO SAMSUNG WEB SITE FOR USER GUIDE.
Oct 07, 2011 | Samsung LN-T5271F 52 in. LCD Television
I have a Samsung LCD (LN-T5271F) about 2 years old and lately when I turn it on, it clicks on and off several times before it actually stays and the tv comes onI have a Samsung LCD (LN-T5271F) about 2...
Call Samung customer service, they are doing this repair for free. I had the same problem at 11 months, they replaced the power supply board under warranty. At 2 years I had the exact same problem again and this time they replaced 2 - 50 cent capacitors on the power supply board. It took the repair man less than an hour and he had the replacement capacitors on hand. The original board and the replacement board they gave me had capacitors that were faulty. Hopefully these new capacitors will last. I have to say that I was thinking (no more samsung products for me) but I got excellent customer service and they admit that they had a faulty product and they accepted responsibility.
Apr 26, 2010 | Samsung LN-T5271F 52 in. LCD Television
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
Picture on Samsung LCD LNT5271F is blurred sometimes, lines, color distortion, double images, then goes away and will come back.
Try reseating the LVDS cable.It runs from the main signal board to the T-con board at the top of the panel.
Dec 01, 2009 | Samsung LN-T5271F 52 in. LCD Television
Samsung power-up problem
two 2200uF capacitor, two 1000uF capacitors on powersupply board.
Replace it! you will save $300.
Jun 19, 2009 | Samsung LN-T5271F 52 in. LCD Television
Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Mar 08, 2008 | Samsung LN-T4671F 46 in. LCD Television
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Open Questions:
Magnavox MWR-20V6 DVD/VCR recorder fails to record one time but not the next This problem just recently started as the unit was functioning perfectly up to now. And I've kept the unit in excellent condition and free of any dust. What's happening is this. When the timer is set to record a program, the unit will turn on and begin to record. But after about 9-10 seconds of recording, it will fail and you'll see an error message saying you cannot record on this disk. FYI, this happens too when not using the timer and just pressing record. And in both cases, it's been hit or miss, so one time it successfully records no problem and the next time no. So you don't know when and if it's going to happen, which is really frustrating! What's even weirder is that once it failed, you can wait a few seconds and try recording again with possible success. So if it failed at first, it may work the next time, but who knows if it'll work after this. And even if it does work the next time, after that, it's again hit or miss. This recording problem happens even when dubbing. So it doesn't matter if you're copying from VHS to DVD, using the time, or just hitting DVD record, the same recording error happens. And as I said above, it may work the next time but who knows? And even if it worked then, anytime after that is also very hit or miss. Nobody else touches the unit and it's never been moved or banged. So again, I've kept it in very good shape and working order. No problems whatsoever on the VCR side. And I most often use DVD-R discs rather than RWs, but even with RWs, the same problem can happen. Lastly, finalizing has also become more hit or miss now when it used to be very consistent. So I don't even know when or if it'll be successful in finalizing a discs. Most times, it does work, but a couple of times, it hasn't. Lastly, a weird thing with discs that failed to finalize is this. A few of them were finally able to be successfully finalized after just sitting around for about a month of not being able to be finalized. So for whatever reason, a few of those discs that wouldn't repeatedly finalize suddenly worked. The rest of those that were not successful still cannot be finalized. And I've kept all these discs in plastic sleeves or in a disc case.
Jan 17, 2018 | Magnavox Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
