Question about Whirlpool ET9FHTXMQ Top Freezer Refrigerator
Whirlpool refrigerator Model Number ET1FTTXKQ03 Keeps freezing
The top mounted freexer keeps freezing. We have stopped running the water line to the fridge, but problem started prior to this. I have totally defrosted the freezer and have tinkered with the settings. I do not know how to check the theromostat or the defrost timer to see if they are working. Any advice? There is a "drainage" chamber in the back that gets copletely iced up. It seems that I am getting condensation from somewhere, but it also seems like it seals well. There is not frost all over, just frozen water all over the bottom! Thanks
  • Fink38 Nov 10, 2008
    I have tried that, wel not taking the rear panel. I will try that and see. I have never checked for flow or not. The next qyestion is why does it get clogged?
  • Darrell Pinkerton Feb 28, 2009
    Same problem here. I have removed and defrosted the entire thing.
    It fixes the problem for a few days - then right back the the refrigerator shelves full of dripping water.
    I have noticed that the Ice Maker gets clogged with ice on the inlet funnel. I am thinking the the water line is dripping into the freezer and freezing the ice maker before it can refill. So when the ice maker tells it to refill the tray - the water spills into the freezer and the overflow hole.
    This has been going on for 6 months or so.
    Any suggestions?
  • Whirlpool Master
  • 2,651 Answers
Common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Nov 10, 2008
  • Ron Coons
    Ron Coons Nov 10, 2008
    can freeze for any number of reasons, flukey thing i problably clear/clean 1 or 2 a month at work, and answered this question probably 9 times this month alone on this site.
How do I fix my refrigerator which keeps leaking water and then freezing on the top shelf. Their is never any water in the pan under the fridge. It also builds up ice in the draining tube.
need to clear the drain tube has bend/buildup or debris in it if access to an air compressor in the inside pan where drain line hooks up blow line out to lower pan
Jun 05, 2016 | Whirlpool Gold GB2SHDXPS Stainless Steel
My whirlpool fridge makes a loud humming noise when the door is closed. It is not freezing items in the freexer and is not cooling items in the fridge section. The freezer is above the fridge section in...
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 11, 2010 | Whirlpool Refrigerators
Icemaker water inlet keeps freezing
This problem is caused from a bad water valve. The water line that connects to your refrigerator hooks up directly into your water valve. The way it works is this. The water valve keeps the water pressure to OFF. Whenever your ice maker needs water it simply asks the valve to open and it does. The problem is this. The valve has malfunctioned and isn't totally shutting off anymore. This lets a tiny bit of water through. This water slowly makes its way up the water line into the freezer where it freezes in your tube :) You just need a water valve! With a model number I can give you an average price. Chances are it will run anywhere from $30 - $50. Just depends on where you get it. This is also a very easy thing to change!
May 27, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice forms under tray in freezer - then water drips into refrigerator - this has been going on for at least 3 years - and we are at wits end trying to keep the drain from freezing up - what to do - the...
Whirlpool has a kit to stop the drain from plugging up. You mount a metal tab on the heater and it is long enough to slip down into the drain. When the heater comes on some heat gets transferred into the drain hole and keeps it from ice blockage. fed15be.jpg
Apr 08, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Hollow ice cubes and refrigerator freezer drip pan is freezing
The drain at the bottom of the evaporator on the freezer rear wall is blocked up. Ice may have gotten so far up the side of the evaporator that it is blocking a return air duct which is located there. You need to completely deice the freezer and then **** out and purge the drain hole on the bottom of the evapotrator with hot water and a turkey baster.
Apr 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker water supply line keeps freezing at nozzle
sounds like your defrost module may not be working, if that is the case it will Freeze up the tip then the line it also leads to a Cracking of the Flex pipe and the Water Filter lines hope this helps if you have a model number i can take a more in depth look at it
Jan 19, 2018 | Refrigerators
The copper line under my s. b. s. fridge keeps freezing
the line that you ae seeing is the suction line . It sounds like the defrost timer may have gave up the ghost on you and the unit is not going into defrost. Take the model Number and make to the local parts house and have thenm get you a timer. They are real easy to replace and that should take care of the problem.
Jan 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Whirlpool ET9FHTXMQ Top Freezer Refrigerator Logo
531 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
