Question about AEG Lavamat 16810 Front Load Washer/Dryer
Drying function not working properly
The drying function on our machine isn't working properly. The programme will start however the air is cold rather than hot. It has flashed E70 up on the screen, however this code is not featured in our user guide. Any ideas what the problem could be?
    Problem Solver:
  • 18 Answers
If you can feel air blowing then it is not the fan, the only other things that are there are the thermostats(2) and element
Posted on Jul 11, 2007
SOURCE:
My Fagor innovation washing machine is currently disabled by the child lock symbol we did not apply this how can it be reversed
STARTING UP AND
6
BLOCK FUNCTION SELECTION
Start/pause button
a To start up the washing machine you
have to press the start/pause button.
The minutes remaining until the end of
washing and drying will appear on the
display at all times.
Block function selection
The lock function ensures that the programme
will not be affected if any buttons are pressed.
It is used when children could press the
buttons, etc.
The block function should be activated after
the wash programme has been selected
together with all its options.
Activating the block function
a The block function is activated by
pressing the start/pause button and
holding it down for at least 3 seconds.
The display will show if it is activated.
Deactivating the block function
b The block function is cancelled when
the wash programme comes to an end.
If you want to deactivate the block
function before the end of the
programme, you have to hold the start
button down again for at least 3 seconds.
After 3 seconds, the block function
indicator will disappear from the display,
and it will go into pause status.
The ON/OFF button does not cancel
the block function
Apr 14, 2015 | Fagor Washing Machines
Machine only one direct rotation (Clockwise) even stop and can't be continue to working at all washing programme
it could be that the water sensor is not Working properly telling the programmer that there's water in or out of the machine unplug the machine take the back off and locate a small 5mm pipe leading upwards take it off and blow gently into it you should hear a click and one when you let the air out if so the place you took the pipe from is blocked not allowing the sensor to work correctly use a pipe(smokers) cleaner or metal rod to clear refit the pipe and rear panel run machine eric
Jan 18, 2018 | Samsung WF306BHW High Efficiency Front...
Hoover washer dryer Error Code E12 during dry programme. How can I fix?
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
Nov 03, 2012 | Washing Machines
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
How to cancel drying?
Please press the reset switch which should be on the control panel or next to the loading door
Nov 14, 2009 | Indesit WA 115 Front Load Washer
Dryer only blowing cold air, washing cycle fine.
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element washer motor has heat overload sensor
thumbs up
Aug 17, 2009 | Washing Machines
Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Oct 13, 2008 | QuietLine WD-9900 Front Load Washer /...
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
AEG Lavamat 16810 Front Load Washer/Dryer Logo
641 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
