Question about Sony SDM-HX73 17" Flat Panel LCD Monitor
Sony SDM-HX73 LCD Monitor
Screen goes black after a couple seconds... This Monitor was ok for a couple years, before this.
Power Supply...?????
  • hurtleyc Nov 12, 2008
    Re-Booting Power Supply/Monitor is not a Answer.....Not a Solution
  • 73 Answers
If the problem is not the power supply and if you can connect your computer with other monitor, try these options in order to see if the problem is the monitor or the adapter
1 - Control Panel--> display --> Double click--> properties--> settings--> advanced--> adapter--> this will check if the problem is with the video card
2 - If you can, check also the directx settings--> Start--> run--> dxdiag--> OK--> Display
If all the above options are OK.... then then the monitor is done
Posted on Nov 12, 2008
    Sergeant:
    Champion:
  • 283 Answers
HI
did you see the standby light? i have standby light you need to oscillate the power switch! or else you have defective power oscillation... please dont rate me if you are not satisfied..
Thanks!
  • amin dianalan
    amin dianalan Nov 12, 2008
    Have you tried with other monitor?If just the same with other monitor;
    1. right click then go to properties
    2. go to screen saver
    3. select power
    4. check the settings for desk power schem
    5. set the time of "turn off monitor" "turn off harsd disk (set to NEVER)" "system standby (set to NEVER)
    Thank you... please don't rate me if you are not satisfied...
    Brigadier General:
  • 6,966 Answers
Based on the age, it is possible that the monitor has some components faulty or near end of life. Although the power supply would be one of the suspects, the best is to open the unit for a look & see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Foremost to consider checking would be power devices, regulators, capacitors and even the solder joint/connections.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
  • Sony Master
  • 6,487 Answers
This monitor already needs some part replacement so it will be better for you to take it to a repair center so they can repair it to avoid further problem.....
  • 4,472 Answers
Are you planning on trying to repair this yourself? You can get an estimate from a sony authorized repair center or locate a local repair store. I can assist you further once I have more information. You may also want to consider replacing the monitor for a new one as 17" have come down in price.
Thanks,
Lee
    Genius:
  • 1,550 Answers
You need to check power supply ?
Posted on Nov 10, 2008
  • SAM ANDERSON Nov 10, 2008
    Turn off monitor for 30 minutes and once again turn on .
    Mostly this will solve your problem temporarily .
    Also gently tap on monitor so that if there is any loose connection it gets rectified .
Monitor picture comes on for only 1 second and then it is blank (black) Color bars appear to be OK (for that second) when running the Self-diagnosis function.
timothy henr, Do you understand how the new screw-in, curlie-Q, energy efficient, CFL light bulbs generate white light?? You will when you find out just what makes the WHITE fixya background on this web page you are looking at!!! Black screen of death can strike at any time!! Do a reply when finished with your research of repair video clips at YOUTUBE. Your search terms are: "lcd monitor disassembly" and "lcd monitor repair." That should get you started. Your unit could have a "switch-mode-power-supply" that detects a problem with itself or another circuit and goes into "full" or "partial" shutdown mode. You should be able to tell the difference if you shine a bright flashlight 1 inch from screen when it goes black!! Partial=still see win-desktop. Full shutdown=no see desktop!!! What wil you do??? Fix or just trade up for new display?? 12fixlouie
Oct 15, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
Monitor going to sleep
juanmgerman0, Connect SDM-X82 to known-good pc that has all sleep mode, power-save mode disabled. (turned-off) If unit still goes to black screen mode, then look at the "date of Manufacture" on rear of unit and let me know if you see "2002 -2004" as the year produced. Retrevo lists unit as "time to retire". Power supply may be going into shut-down mode having detected a problem with itself or the CCFL inverter circuit. 12fixlouie
Aug 19, 2010 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
Cant find vista driver for monitor Sony SDM-HX73
Go here and do some searching for a driver that will work. http://driverzone.com/device.php?id=54867 If you do not find one, then I suggest you contact Sony at> http://esupport.sony.com/US/perl/contact-land.pl?mdl=SDMHX73
Nov 28, 2009 | Sony SDM-HX73/B (Black) Monitor
Sony sdm-hs75p runs for 5 odd minutes then screen goes blank?
h_e_l_l_f_i_, Have you performed the flashlight test after the screen goes "BLANK" ?? No!! You will not find the "flashlight" test listed in the OWNERS manual!! The test is a quick evaluation of the STATE of the units "switch-mode-power-supply". Did you repair the power supply to get online to fixya? The more info you tell me about your LCD monitor the better I can assist you. Is the unit really "BLANK" or is it just "BLACK"?? Can you SEE the WIN-desktop when a bright "flashlight" is held 1" from the screen at different angles? If you can see a faint image being displayed it means the SMPS is in partial shutdown and still powering the VGA to LCD interface board. If unit is both BLACK and BLANK, then SMPS is likely in full shutdown mode! I will assume that when you stated "runs" for 5 minutes, that it would display normal text and graphics as usual and NOT be wearing a pair of NIKE's runners footwear? Yes! From your description it would lead me to think that your SONY has a SMPS/INVERTER problem. You failed to state the age and or approximate TOTAL "ON" hours the unit has. (hrs/day x 350days x Years since DOM). It makes a difference in whether I tell you to trade up to a wide screen or have it repaired(refurbished with new SMPS/INVERTER or just rehab the SMPS on your own. hellfi, surely, after reading this you WILL go to YOUTUBE, (just fyi) and view some of the longer video clips of "LCD monitor disassembly" and typical "LCD monitor repair"!! You WILL be impressed at how much you will learn about how "the black screen of death" is dealt with. If this response helps in any way, please rate it on fixya. 12fixlouie lmistyrel @ aim.com Get back to me if further assistance is required asap!!!
Nov 23, 2009 | Sony SDM-HS75P/S 17" LCD Monitor
Sdm x73 screen goes black
Here is one thing you can do to help get to the root of your problem.
Take a flashlight and shine it on the screen once it has gone to black. If you are able to see the screen information (your desktop) then you have a back light problem.
The fact that the bulbs come on at first and then go dark tells me that it is probably not the bulbs themselves and the fact that your power led stays on tells me that it is probably not the power supply either.
The most likely cause is the power inverter board which is usually a separate board attached to the video mother board and it powers the back light bulbs.
This is not an easy fix for someone who is not familiar with LCD displays but it can be done. I did a Google search on Sony SDM-X73 (if that is your monitor) and could not find any stand out instances of complaints. I also did a eBay search and could not find anyone selling replacement boards either.
Truthfully, my solution for you would be to replace the monitor. It will probably cost you more to have someone work on the monitor and fix it than it is worth. You can find 17 inch flat panels on eBay or CraigsList for cheap these days and I just saw a brand new Acer 22" with a 3 year warranty on CompUsa.com the other day for $150.00.
You can try taking it apart if you want to but recycling it is the better option.
Good Luck,
John
Aug 28, 2009 | Sony DELUXEPRO SDM-X73/B (Black) 17" LCD...
Power light comes on green for a second then goes orange, then red with no test screen just stays blank
Check the CPU, If ok then check the CRT neck pcb supply and pcb area..may be dry solder..
Jun 25, 2009 | Sony PremierPro SDM-P232W/B (Black,...
Sony SDM HX73 LCD screen - pungent odor bugging me
If the monitor is working well you need not worry. If any electrolytic capacitor burst out this type smell may come.
Dec 10, 2007 | Sony SDM-HS73P 17" LCD Monitor
same thing with my computer
Oct 04, 2007 | Sony SDM-HX73 17" Flat Panel LCD Monitor
Black screen after 1/2 second power-up of Sony SDM-HS73
bratty, do you have a pic on which capacitor this is? Also where I can find a replacement one.
My monitor is doing the same thing, nice and bright for 1/2 a sec then goes super dull, you can barley see anything.
Thanks,
Jake
Oct 01, 2007 | Sony SDM-HS73P 17" LCD Monitor
Sony SDM-HS53 Monitor Goes Blank
I used to have the same problem until I discovered that the cables in the back of the monitor weren't securely connected. I have a very similar model monitor to the one being displayed here
Apr 03, 2007 | Sony SDM-HS53 (Black) (Gray) 15" LCD...
Sony SDM-HX73 17" Flat Panel LCD Monitor Logo
155 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
