Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Error 11 code
Hello, Thought that I would post a question concerning my 4 year old Rinnai RHFE-1004FA(LP) wall furnace. A few days ago the unit was shutting down with an Error 11 code. I have been doing the maintainence cleaning of this unit since we had it and hadn't had a chance this year so I went ahead and took off the front panel and got rid of the dust,etc. After cleaning it up and putting it back together, it has been running fine for over 24 hrs. There were a few things I noticed while I was in there that I wanted to ask about. First, a small clear plastic tube that was connected to the exhaust port (I think) wasn't seated as well as it should, which I re-seated. Could have this been the culprit? The other thing that I noticed was that gas line #2 was not nearly a snug withing the fitting where it attaches to the burner. The other two lines have no sway, but this one you can move, even though the nut is snug to the housing. Is this a concern, and should I perhaps have someone look at it? Past that, the unit is running fine now. Thanks. WK
  • 944 Answers
If the gas lines are moving or vibrating regularly, especially as they get older there is a possibility of fracture, so I would get them tethered properly. if no obvious vibration or risk of movement then they are probably fine if you are sure there are no leaks other than that i just found this manual earlier on for another user: - hopefully it can answer your questions http://www.rinnai.us/Rinnai.aspx/FileLibrary.aspx/DealerResources.aspx/DocumentsLibrary.aspx/WallFurnacesDirectVentMainHeatSource.aspx/RHFE1004FA.aspx/GeneralInformation.aspx/456RHFE1004FAManual32003.pdf.aspx Hope this helps :)
Posted on Mar 01, 2007
Newly installed rinnai rhfe-1004fa gas heater will not start up
I don't know what's the matter with fixya site it's getting to be a real pain in the as>
Dec 07, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My Rinnai 1004F giving me error code 99
This fusible link may be open. Try jumpering the two leads and see if the unit operates. If it does replace the fusible link. Do not operate the unit without the fusible link for an extended period. It is a safety device and is there for a reason. Hope this helps.
Jan 04, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a nat gas furnace that has 5 flashes on the board and will not light
Check for error code and check filters are not blocked and you have correct pressures. Make sure flue is not blocked
Dec 13, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
The furnace shuts itself off.
Is it giving you any error codes? Can you give us any more details like how do you get it started or is there a noise associated with the failure?
Nov 11, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I'd like information on the reliability of Rinnai 1004FA furnaces. Do they need regular cleanings?
Beside the filters in the back, no they don't require much. After 8 years of installing and servicing these units, I haven't found a unit yet that was running faulty due to lack of service. Would recommend a cleaning of the burners about every 3-5 years. Rinnai recommends cleaning the unit with compressed air through the front grate annually...but that doesn't require disassembly
Sep 11, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Flashing code 99
Error code 99 has to do with the flue pipe being blocked. You could have ice or frost on the exhaust or air intake. This reduces the combustion air to the unit which in turn stops the fuel flow.
Tom Hawkins
hawkins111@gci.net
Dec 21, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
556-P Error code 53
I would recommend you read this, hope it helps:
Rinnai Recalls Wall Furnaces Due to Carbon Monoxide Hazard
clip this post email this post what is this?
see most clipped and recent clippings
Posted by saltcedar (My Page) on Thu, Feb 21, 08 at 19:28 NEWS from CPSC
U.S. Consumer Product Safety Commission
Office of Information and Public Affairs
Washington, DC 20207 FOR IMMEDIATE RELEASE
February 21, 2008
Release #08-199
Firm's Recall Hotline: (866) 746 8344
CPSC Recall Hotline: (800) 638-2772
CPSC Media Contact: (301) 504-7908
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in
cooperation with the firm named below, today announced a voluntary
recall of the following consumer product. Consumers should stop using
recalled products immediately unless otherwise instructed.
Name of Product: Direct-Vent Wall Furnaces, Models RHFE 431 and RHFE 556
Units: About 52,000
Manufacturer: Rinnai America Corp., of Peachtree City, Ga.
Hazard: A gasket in the unit can fail, posing a risk of poisonous carbon
monoxide gas leaking into the home.
Incidents/Injuries: Rinnai has received 11 reports of carbon monoxide
leaking from the furnace. No injuries have been reported.
Description: The recall involves Rinnai EnergySaver Direct-Vent Wall
Furnaces, Models RHFE 431 and RHFE 556. They are either natural gas or
LP gas (propane) fueled. The following model numbers are included in the
recall:
Model RHFE-431: FAIII-N, FAIII-P, WTA-N, WTA-P, WTA-72B-N, WTA-76B-N
Model RHFE-556: FAIII-N, FAIII-P, WTA-N, WTA-P
The model number is printed on the top of the rating plate located on
the right side of the unit. The recall includes only those units
manufactured from February 2000 through December 2007. The manufacturing
date code is the first four digits of the serial number, written as YY
MM, and is located at the bottom of the rating plate.
Sold through: Wholesale distributors nationwide to contractors and
dealers from February 2000 through December 2007 for between $1,600 and
$1,900.
Manufactured in: Japan
Remedy: Consumers should stop using the furnace immediately and contact
the firm to arrange for the installation of a free repair kit.
Consumer Contact: For additional information, contact Rinnai toll-free
at (866) 746-8344 anytime, or visit the firm's Web site at
www.wallfurnacerecall.com
To see this recall on CPSC's web site, including pictures of the
recalled products, please go to:
http://www.cpsc.gov/cpscpub/prerel/prhtml08/08199.html
The U.S. Consumer Product Safety Commission is charged with protecting
the public from unreasonable risks of serious injury or death from more
than 15,000 types of consumer products under the agency's jurisdiction.
Deaths, injuries and property damage from consumer product incidents
cost the nation more than $800 billion annually. The CPSC is committed
to protecting consumers and families from products that pose a fire,
electrical, chemical, or mechanical hazard. The CPSC's work to ensure
the safety of consumer products - such as toys, cribs, power tools,
cigarette lighters, and household chemicals - contributed significantly
to the decline in the rate of deaths and injuries associated with
consumer products over the past 30 years.
To report a dangerous product or a product-related injury, call CPSC's
hotline at (800) 638-2772 or CPSC's teletypewriter at (800) 638-8270, or
visit CPSC's web site at www.cpsc.gov/talk.html. To join a CPSC email
subscription list, please go to https://www.cpsc.gov/cpsclist.aspx.
Consumers can obtain this release and recall information at CPSC's Web
site at www.cpsc.gov.
Mar 10, 2008 | Rinnai EnergySaver 556 Air Conditioner
Error code 11 on my rinnai
A code 11 also means that it might not be getting any gas. On thr right side of the unit you will find a small door. open it up and make sure the valve is in the open position. If it is, you should contact your gas company to come and diagnose what is going on. The Rinnai is not a do it yourself fix it type of heater.
Nov 06, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
233 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
