Question about HP Computers & Internet
My hard drive is "hanging up" and sometimes does not start. The computer will start, keyboard light momentarily lights but hard drive will not start. The only way I can seem to get it started is to turn the computer on - leave it on for about 15 minutes then shut it off and retry to start it. Then it will start.
  • 44 Answers
There is a possibility your hard drive is failing.Go to the website of your hard drive manufacturer and download a diagnostic utility. Run the diagnostic utility to determine whether the hard drive is in good condition.
Posted on Nov 10, 2008
The computer will not boot
Possible that PC is hanging up as there is fault on the OS (operating system) or a virus in the OS. Also it is possible that the backup battery (CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. Sometimes the memory card connections can be faulty either on the card or on the slot. Cleaning the slot and card must be done before you try a replacement. If the PC boots and fails then the hard disc can have bad sectors or is corrupt. However if there is no result the motherboard also can be suspected. In this case you might need the help of proper tools and equipment support to do a chip level service.
Jul 03, 2012 | HP Computers & Internet
Dell OptiPlex GX110 hangs at post
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope it helps
Apr 10, 2012 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
Hi. my flash drive light comes on as i put it in. it stays on momentarily but after three seconds or so th ligh goes off. it doen't even show up on my computer
Flashing light means your flashdrive is being read. Try it on another computer, if it still can not be detected then it is broken.
Hope this helped! =)
May 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hey there. I have a problem with an external harddrive. "My Passport Essential". When I connect it to my compute sometimes nothing happens and sometimes "Local Disk (E:)" shows up in my...
The problem might be a loose connection or bad configuration file (an autostart ini file that makes the hard-drive do certain things when plugged in) in the root folder of your hard drive. Are you able to connect to it sometime or it doesn't work at all? If you can read it, try backing up all your data and format the hard drive and copy back the backup again. But remember to copy only the needed files and not the system or ini files.
May 06, 2011 | Western Digital My Passport Essential...
My Acer Aspire X1700 hangs at the Acer boot screen after a power outage. The power flickered a few times. I use a surge protector. Now when it starts it hangs at the boot screen. It doesnt do anything when...
HI
it seems that there is some static electricity stored in the computer..........do you leave the computer turned on 24/7?
anyways...here is the fix...
turn off the computer(make sure there are no lights on the keyboard)
disconnect all the cables(including the power cable)
press and hold down the power button for 30 to 40 seconds and release it.
plug in all the cables
turn on the computer
this should work(this releases the static which is stored in the computer)
to avoid this make sure the computer is off when its not in use.....
if that doesnt work you try reseating the hard drive
or you can try to enter to bios to test the functionality of the hard drive
tap f10 or f2 key as soon as you turn on the computer
keep tapping it till you see a screen
press NO if you are asked to choose yes/no
look for advanced>>primary hard disk self test>>run the quick and comprehensive test to check the functionality
if you are able to enter into bios(hardware is fine)
try to go to SAFE MODE by tapping F8(ADVANCED BOOT OPTIONS)
SAFE MODE>>START>>RUN>>MSCONFIG>>START UP>>DISABLE START UP ITEMS>>APPLY>>OK>>
RESTART THE COMPUTER
this should work
please have some patience and try doing this your computer should work
have a good day
Mar 01, 2011 | Acer Computers & Internet
Blank Screen - hard drives work and keyboard lights up
Try holding F11 while booting, sometimes this triggers the recovery partition.
Sep 21, 2009 | Compaq Laptop Keyboard for HP Pavilion...
WD320GB hard drive not working
Are you using a double power USB cable, which normally comes with W/D hard drives?
Also if the light on hard drive blinks the drive is not getting enough power from the USB port.
All the best!
Aug 11, 2009 | Western Digital WD Passport 250GB Portable...
Acer 5100 laptop mouse/keyboard not working
Your local electronics store has a USB keyboard and mouse port dongle. Or if you have a USB keyboard or mouse. Once you get functionality, choose Start>Run and type in "CMD" without quotes and hit enter. You will get a black box with a command line, enter:
chkdsk /r
Windows will inform your the disk is in use and cannot perform, you choose yes and it will do so upon the next restart. Restart the machine and let it run the disk check utility. Place your ear on the palmrests (usually where hard drive is located inside bottom half of laptop). Listen for sudden hard clicks, similar to huccups. When it makes those noises the hard drive light usually stays solid, afterwards the hard drive will repeat the same "bad sector check" sound. Finally, if you notice the process taking more than a few hours, your disk is in trouble. Recover the data using an external drive bay (also at electronics store) and place the drive inside the bay and recoverit to another computer. Order a new hard drive, intall, and re transfer your files by any media or network.
Jan 06, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
103 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
