I have a1989 Projection Color TV. Had a repair man a few years back who has since died. He popped the front off, squirted the screen with Windex, wiped with paper towels and left. Can you tell me how to pop off that front. Have lots of young males here ready to help. Thanks, Pat
    Brigadier General:
  • 6,966 Answers
Initially, pls postback the brand and model number. Different brands and models have different designs although normally, there would be clasps/lock on the edges and depending on the size midway.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
    Genius:
  • 1,550 Answers
  • You need to turn off the TV to allow the lenses to cool, and unplug the set to be safe.
  • Then, remove the screen protector from the front.
  • The protector will "pop" off of the front, just pull gently outward on the frame until one of the sections pops loose, then work your way around the frame until it's loose.
  • The screen protector is held on by small round “nubs” that fit into holes in the protector frame.
    Sergeant:
    Novelist:
  • 196 Answers
Its actuall fitted with screws and plastic looks.just take the proper screw driver.and start.
I have what I think is a Hitachi 55 inch ultravision rear projection TV that is 12 years old. I think the model is 55UX58B. The color goes out and it becomes black and white. It comes back after a few...
When the tv is it totally black and white and the tv picture are good and clear wright?when the tv colors are fade in and out are clear up and when the tv picture it is in colors it is look good normal picture wright?Tv have no shadows of any kinds of colors when picture are good in colors wright?Yes,take ur hand make fist or take a wooden hamer bangs all around the tv bazel frame if the tv colors come back or tv stay in colors it is have good picture in colors.Tv it is still good just have components parts are cold soldering or CRT colors guns R,G,B just require resoldering works only.
Aug 22, 2011 | Hitachi 50UX57B 50" Rear Projection...
Liquid got between frame and screen how do i get it out
need to dis assembly the frame of the tv and take the 3 screens out and cleaned may sure you put this back in the same way you took it o each side is different do not use any cleaner like windex
Dec 18, 2010 | Mitsubishi WD-60735 Projection Television
White dots all over the screen
White dots are due to bad DMD chip and qualified tv tech can replace required DMD chip in this tv to fix the picture issue.
Please contact nearest Samsung service center or local tv repair shop for repair estimate.
Thanks.
May 16, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My color is off on my whole tv i have a 52''projection toshiba cinema series the old big style and was wondering how to adjust the colors so they match up
Sounds like what was wrong with mine! Take the remote and hit menu, then scroll to the Video Adjust button, then adjust the "convergence" or the color tone, brightness, contrast etc. My repair man did this and it helped get the picture much more life-like. He said over time they get out of line and just need a few adjustments. He just charged the $50 house call. Good luck, hope you can fix it.
Dec 11, 2009 | Toshiba 50H81 50" Rear Projection...
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
Mar 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture getting dark on my 70" mitsubishi projection
Good Day;
It sounds like your lamp is getting weak, replace lamp. Good Luck, big IRISH.
Oct 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV problem 46GW948 GE 48? Thomson Guide Plus GemStar
i hope this helps. on the tv, press menu, then channel up or down to "screen", then menu;
then channel up or down for adjust projection tv(6), then press menu;
then use the volume up and down, as well as the channel up and down until each of the 3 colors are lined up. press menu after each color i slined up to go to the next color.
hope this helps.
May 29, 2008 | Televison & Video
Colored lines in my projection tv
my cousin had the same problem. He had to call a repair man. Apparently there are some adjustments to fix this problem. He said it only took the guy about 15 minutes and done.
Dec 31, 2007 | Televison & Video
I have a 6 year old Samsung PCJ522R 52" TV.
It sounds like at least one of 3 "IHVT",s popped. in short, a "IHVT" is a high voltage transformer. It will have to be replaced along with any other parts that were damaged in the process.
They do produce a strong odor when they pop!!
It is repairable but at a price. there is a good chance that parts will have to be ordered.
you might consider buying a new LCD HDTV instead of fixing this one.
Dec 27, 2007 | Samsung PCJ522R 52" Rear Projection...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
